Easiest way to change front torsion bars. |
tornik550 |
Sep 17 2014, 04:03 PM
Senior Member Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
What is the quickest and easiest way to change the front torsion bars.
SirAndy |
Sep 17 2014, 04:08 PM
Resident German Group: Admin Posts: 41,651 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
What is the quickest and easiest way to change the front torsion bars. Jack up the front of the car, unbolt the end caps and take them out. (IMG:style_emoticons/default/smile.gif) |
bdstone914 |
Sep 17 2014, 04:20 PM
bdstone914 Group: Members Posts: 4,525 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
What is the quickest and easiest way to change the front torsion bars. Jack up the front of the car, unbolt the end caps and take them out. (IMG:style_emoticons/default/smile.gif) They often get stuck in the spline area in the front. I drive the bar further in to pop out the cap in the front of the A arm then use a big punch to drive them back the other way. That also allow you to clean the splined area of old grease and rust. The cap can be reused in most cases. If not Stoddard carries them. Same as early 911. |
Lo-Fi Version | Time is now: 23rd May 2024 - 07:37 PM |
