Changing a /6 belt isn't so bad!, When you have the right tool |
patssle |
Sep 20 2014, 01:38 PM
Senior Member Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None |
After reading how terrible and hard to change a belt on a /6 engine is - I wasn't looking forward to fixing my squealing belt (ended up figuring there's a good reason flat-sixes have 6 washer-rings for the fan pulley - my pulley was loose and rattling).
Getting the washers/pulley on by feel takes a few tries but is easy along with the belt and tightening it. I am no longer afraid of changing my /6 belt and definitely won't be cutting any holes into my firewall! |
GeorgeRud |
Sep 20 2014, 02:12 PM
Though I didn't put quite as many bends in mine ( I cut the wrench shorter), I found this to be valuable. Being able to see what you're doing is so over-rated!
Lo-Fi Version | Time is now: 16th May 2024 - 09:11 AM |
