Air Filter Options, for 1974 1.8, dual Webers |
mobymutt |
Sep 21 2014, 04:16 PM
Senior Member Group: Members Posts: 548 Joined: 16-December 13 From: Kingston, Ontario, Canada Member No.: 16,770 Region Association: Canada |
I currently have K&N filters. We live on a dirt road which gets extremely dusty in the summer, and I am wondering if I should change to paper filters. Is this a good idea? If so, what are my options? If not, should I just clean the K&N's, or should I buy new ones?
GeorgeRud |
Sep 21 2014, 04:35 PM
If you could locate a paper filter element that would fit the K&N filter assembly, that would probably be the best. Also, using the rain-hat upper covers might be helpful as well. Hopefully someone has a filter number that might fit. I think perhaps an outfit that specializes in dune buggies might have suggestions as they play in the sand.
Otherwise, clean and keep the K&N filters oiled. |
02loftsmoor |
Sep 21 2014, 04:40 PM
Senior Member Group: Members Posts: 577 Joined: 26-June 11 From: Ft. Worth TX Member No.: 13,243 Region Association: Southwest Region |
let me know if you decide to ditch the K&Ns
rmdinmd |
Sep 21 2014, 06:05 PM
Member Group: Members Posts: 488 Joined: 30-October 13 From: Greeneville,Tn Member No.: 16,585 Region Association: South East States |
There is a kit for cleaning and reoiling them you can get at the FLAPS. price isn't bad.
DBCooper |
Sep 21 2014, 07:39 PM
14's in the 13's with ATTITUDE Group: Members Posts: 3,079 Joined: 25-August 04 From: Dazed and Confused Member No.: 2,618 Region Association: Northern California |
K&N's aren't hard to clean (and oil), which is probably an advantage if you're doing it a lot, but they really don't do that good a job of filtering. If your dust problem is really serious (you wash your car a lot?) I'd suggest you use paper filters, which I assume they still make, it's been a while, and a set of Outerwears over the top. It's a dune buggy thing, a foam sleeve that fits over those KN filters and kind of "pre-filters" the biggest crap to make the paper inner filters last longer. Look on the CBPerformance site, for example, see what they have that best fits your particular situation.
ChrisFoley |
Sep 22 2014, 07:52 AM
I am Tangerine Racing Group: Members Posts: 7,922 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
mobymutt |
Sep 23 2014, 09:45 AM
I found this paper filter and housing, can anyone verify that it will fit?
http://www.cip1.ca/ProductDetails.asp?Prod...de=ACC-C10-5651 |
Lo-Fi Version | Time is now: 6th May 2024 - 03:49 AM |
