getting under the heat shield..., how the heck do you get in there? |
barebrad |
Sep 21 2014, 05:05 PM
Member Group: Members Posts: 54 Joined: 13-September 13 From: Huntsville, Al Member No.: 16,382 Region Association: South East States |
Alright folks, I've been cleaning, grinding and sand blasting all day. I'm trying trying to figure out how to get under the heat shield? Do you cut it out? Just leave it alone? (I'm to OCD to do that!) I'm thinking about cutting it out and weld in some studs and I can bolt it in after paint. What do most do?
Thanks |
Spoke |
Sep 25 2014, 05:00 PM
Jerry Group: Members Posts: 6,984 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
I removed the heat shield initially to do some trunk floor rust repairs. Instead of attaching it permanently, I welded bolts on the hangers and drilled holes in the floor for the mounting bolts.
I've now had the shield off 2 times after that to do maintenance under the car. Attached image(s) |
Lo-Fi Version | Time is now: 22nd May 2024 - 03:17 AM |
