squeekie top, what to use and where to get it- to lube the seals |
DRPHIL914 |
Sep 23 2014, 08:52 AM
ive heard glycerine works but where do you source it?
PanelBilly |
Sep 23 2014, 09:23 AM
914 Guru Group: Members Posts: 5,805 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
Ear wax
76-914 |
Sep 23 2014, 09:31 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,497 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
DRPHIL914 |
Sep 23 2014, 09:38 AM
mgp4591 |
Sep 23 2014, 10:15 AM
914 Guru Group: Members Posts: 5,370 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
Honda (and I believe other Asian manufacturers) use a product called Shin-Etsu grease, non petroleum and doesn't stain (important for interior warranty work) and it silences squeaky window rubber, hatch rubber, door rubber etc. It ain't cheap but a tube would last me a year, working on Hondas constantly. Not every car needed it but a little of this stuff goes a long way and doesn't deteriorate your seals. You can use the extra for hair gel... (IMG:style_emoticons/default/lol-2.gif)
rhodyguy |
Sep 23 2014, 10:19 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,076 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Rite Aid, Wallgreens, etc...last time I bought it Rite Aid in a medium bottle for pretty cheap. Skip the glycerin in capsule form.
TravisNeff |
Sep 23 2014, 10:32 AM
Baby suppositories
BeatNavy |
Sep 23 2014, 10:55 AM
As attractive as the baby suppository solution sounds, you could also go to 914Rubber and replace your rear seal with the one Mikey sells that doesn't squeak. I use that one and have no roof squeaks. Or I don't think I do. It's been a couple of weeks since I drove with the top on...maybe I'm just forgetting.
rhodyguy |
Sep 23 2014, 12:27 PM
not the for babies version. it comes in a plastic bottle in liquid form.
JawjaPorsche |
Sep 23 2014, 02:16 PM
As attractive as the baby suppository solution sounds, you could also go to 914Rubber and replace your rear seal with the one Mikey sells that doesn't squeak. I use that one and have no roof squeaks. Or I don't think I do. It's been a couple of weeks since I drove with the top on...maybe I'm just forgetting. (IMG:style_emoticons/default/agree.gif) |
Johny Blackstain |
Sep 23 2014, 02:20 PM
Walnut Elite Stratocaster player Group: Members Posts: 3,434 Joined: 5-December 06 From: The Shenandoah River Member No.: 7,318 Region Association: MidAtlantic Region |
100% guaranteed not to squeak or leak: Attached image(s) |
Elliot Cannon |
Sep 23 2014, 09:16 PM
You should make your signature a little bigger so we can all see your political comment. (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/av-943.gif)
DRPHIL914 |
Sep 24 2014, 07:27 AM
You should make your signature a little bigger so we can all see your political comment. (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/beer.gif) just added that yesterday- thought i set it for a"6" was not intended to be that big, but i guess it does the job, (IMG:style_emoticons/default/piratenanner.gif) - kind of fits, doesnt it (IMG:style_emoticons/default/poke.gif) edit- its been adjusted a bit smaller, so now you dont have to scoll down to read the whole quote (IMG:style_emoticons/default/wink.gif) |
JeffBowlsby |
Sep 24 2014, 09:53 AM
914 Wiring Harnesses Group: Members Posts: 8,499 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
The tops squeek for two reasons:
1. The metal to metal interface between the retractable 'hooks' and the 'pegs' mounted to the top need isolation or lubrication. I use a small piece of heat shrink over the 'pegs', lube is too messy. Some use small thin pieces of plastic/rubber/vinyl tubing, but it has to be thin wall material for the hooks to engage the pegs. 2. The rear top seal is rubber to metal, where as the original has a felt liner to isolate the surfaces. The cheap repro rear seals don't have the felt and they squeek, be sure your seal has a felt isolator in good condition. |
wndsrfr |
Sep 24 2014, 10:29 AM
Senior Member Group: Members Posts: 1,428 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
ive heard glycerine works but where do you source it? Take a closer look at the contact points on the top of the Targa bar and lube them first...pay attention to the "bumps" that locate the latches....they were the culprit on mine....I put some teflon tape on them. |
rhodyguy |
Sep 24 2014, 11:34 AM
A couple of pieces of adhesive backed felt in the recesses cures the squeeky top standoffs.
Lo-Fi Version | Time is now: 12th May 2024 - 04:19 AM |
