How thick are brand new /4 brake rotors?, front and rear |
Mueller |
Jan 27 2005, 04:08 PM
Brett W |
Jan 27 2005, 04:16 PM
Advanced Member Group: Members Posts: 2,856 Joined: 17-September 03 From: huntsville, al Member No.: 1,169 Region Association: None |
Not thick enough.
.433 in I am looking at another option that should be a bolt on upgrade to an .810 vented rotor and a four pot caliper. I'll keep you posted when I have the other parts to compare to. |
Part Pricer |
Jan 27 2005, 04:17 PM
Believe everything I post Group: Benefactors Posts: 1,825 Joined: 28-December 02 From: Danbury, CT Member No.: 35 |
Mueller |
Jan 27 2005, 04:48 PM
how funny.....I spoke to a Wilwood engineer a few weeks ago that gave me a sneak peak (pdf file) of their new line of 4 piston calipers.... radial mount: 1.38", 1.25" and 1.00" bores available....for rotors .35/.50 and .79/.85 thick...diameter 10.25 to 11.00".... pretty cheap at $150 each (forged as well) thanks for the numbers Paul.... |
Brett W |
Jan 27 2005, 10:09 PM
How about a bolt on 4 piston brake upgrade with an .810 vented rotor with a floating rotor, studded hubs all for less than 400$. You will need a bigger master though. Should know something in the next week or so.
Lo-Fi Version | Time is now: 17th May 2024 - 04:14 PM |
