Will Elephant Quick Change give more adjustment?, (than other offset alum ones) |
mskala |
Sep 26 2014, 06:18 PM
R Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None |
I have had for years the typical aluminum camber plates, I think they are the Tarrett ones but they look like the same design as this Elephant (left side):
The adjustment is limited by the 914's metal 'lip' which hits the raised portion of the part. Question is, will the Elephant 'Quick Change' (right side) allow for more adjustment or will it just hit the same place (i.e. the beefy part under the nut is the same diameter?). Does anybody have first-hand knowledge of the answer? I can contact elephant but I'm not sure they have checked this on 914 vs. 911. Or maybe the strut opening 'lip' is identical for early 911 and 914? Inquiring minds want to know Thanks |
Matt Romanowski |
Sep 27 2014, 01:15 PM
Senior Member Group: Members Posts: 878 Joined: 4-January 04 From: Manchester, NH Member No.: 1,507 |
If I remember right, the offset ones from Rennline looked like they would give the most.
mskala |
Sep 27 2014, 05:32 PM
ThePaintedMan |
Sep 28 2014, 03:09 PM
Advanced Member Group: Members Posts: 3,886 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
Call Chris at Tangerineracing.com. He'll be honest and tell you what he uses, even if it's not one of his own products. Not sure what he uses for the front shock towers, but he used to have his own proprietary solution for the rears.
stugray |
Oct 15 2014, 10:42 PM
Advanced Member Group: Members Posts: 3,824 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
you can also get the offset ball joints that automatically gives you an extra 3/4 degree:
http://www.elephantracing.com/suspension/b...14balljoint.htm |
mskala |
Oct 16 2014, 06:06 AM
you can also get the offset ball joints that automatically gives you an extra 3/4 degree: http://www.elephantracing.com/suspension/b...14balljoint.htm Yeah, I thought of that, but those things scare me. |
Jetsetsurfshop |
Oct 16 2014, 06:28 AM
Senior Member Group: Members Posts: 814 Joined: 7-April 11 From: Marco Island Florida Member No.: 12,907 Region Association: South East States |
you can also get the offset ball joints that automatically gives you an extra 3/4 degree: http://www.elephantracing.com/suspension/b...14balljoint.htm Yeah, I thought of that, but those things scare me. I just I put them in my track car. Clean install. Ran one hpde weekend with them. I did my best to abuse them. No problems here. |
Lo-Fi Version | Time is now: 19th May 2024 - 01:30 AM |
