2.7 with solex and carbs, what pistons? |
Mike D. |
Jan 27 2005, 07:15 PM
OK, It runs now, and pretty good too! Group: Members Posts: 1,445 Joined: 3-January 03 From: Santa Clarita, Ca Member No.: 85 Region Association: None |
Looking for someone who has run a 2.7 with carbs...
Like it says, are the stock CIS 2.7 pistons a good match for solex cams and Webbers? I looking to build a driver, good midrange, 3-6k rpm, no High HP, 9k rpm, airplane fuel race car... Yes, I know, "go read the books", well in the modification sections for both Andersons and Patricks book's, they don't refer to a slightly modified 2.7. -Mike D. |
0396 |
Jan 27 2005, 07:44 PM
Advanced Member Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
Mike ,
You have to cut the valve pockets on the cis pistons ..the solex cams have too much lift. To my knowledge,the most you can get away with is a 'T' cam Good luck (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) |
Cap'n Krusty |
Jan 27 2005, 07:55 PM
You can use the European pistons with "conventional" tops, but you'll still have to pocket them for valve clearance. A good Porsche experienced machine shop will know what to do. Try EMS near LAX. The Cap'n
Eric_Shea |
Jan 27 2005, 11:36 PM
PMB Performance Group: Admin Posts: 19,274 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Why not the ever so popular set of RS P&C's?
Should be a good 210hp with the solex cams. Very drivable. |
J P Stein |
Jan 28 2005, 02:25 AM
Aye, that is, but about 2500 bucks for another 40 real hp. That's cheep in some circles. |
DJsRepS |
Jan 28 2005, 06:22 AM
Member Group: Members Posts: 431 Joined: 4-November 04 From: Sarasota Florida Member No.: 3,060 |
Im surprised Jake did not jump on this thread. Cutting pistons and what cam to use sounds like his cup of tea.
ArtechnikA |
Jan 28 2005, 06:58 AM
Jake "doesn't do 6's" :-) |
Root_Werks |
Jan 28 2005, 07:57 AM
Village Idiot Group: Members Posts: 8,312 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
If you have a decent 2.7 already, I wouldn't touch it. Just put the carbs on, dail them in and be happy. You start putting solex cams in there, notching pistons etc and soon you will have a $6k 200hp 2.7 when you already had a 180hp 2.7 without messing with it. If it is an "S" motor, you already have the S cams, even in CIS form, they are not bad cams at all. Just my opinion. (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
Example: Know two people with 2.7's, one had it rebuilt, bumped compression, used SC cams, kept CIS. Friggen great driver. Runs perfect, plent of punch. Other 2.7 person had builder put in 2.8 P/C's, solex type cams, bump compression ect. Carb'd engine, much more tempermental, still easy to drive, but not much more hp than the 2.7 at all and he spent a lot more $$$ on his engine. The law of diminishing return. |
Mark Henry |
Jan 28 2005, 08:24 AM
Why??? av gas uses a different octain rating system...IMO your just wasting your money. Buy real race fuel, mix it with pump gas if you want, whatever..... |
Root_Werks |
Jan 28 2005, 08:52 AM
A buddy of mine who has a few planes will run AV fuel through his cars (Porsches adn VW's all air cooled) before putting them away for the winter. He says the fuel doesn't go bad. He also said it doesn't burn as well as pump gas. (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) Said that was a mis-conception about AV fuel in cars. It burns slower so you can bump your timing harder, but that is about it. Can anyone else confirm this? I have no reason to doubt this guy. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
Eric_Shea |
Jan 28 2005, 10:16 AM
Nope. About $750 used in very good shape. There were a ton of those kits manufactured. Same price as a good set of Solex cams and less than Webers are going for these days... I though he was playing ball in that park. (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
I think he said he didn't want a "High HP, 9k rpm, airplane fuel race car" |
ArtechnikA |
Jan 28 2005, 10:43 AM
that is just about the textbook definition of octane rating. higher == more resistant to combustion. i've even backed down from the premium i run in the summertime to midgrade. starts better in single-digit temps and makes more heat. |
Cap'n Krusty |
Jan 28 2005, 10:48 AM
Hey! For a mere $16-18K I can build you a nice 275-300 HP 2.7! Somewhat driveable, scary fast, should last a while ........................... The Cap'n
J P Stein |
Jan 28 2005, 02:12 PM
I had a 73 911,CIS 2.7L (PO swap). Nice but compared to my present 2.7L 914 (200 lbs lighter) ...powerwise, it's no contest ....not even close. A friend has a Webered 2.7L , 68 911....same deal.
I didn't factor in a 700 buck set of P/Cs., but... 300-500 for Solex cams 200-250 for a top end rebuild kit 100-150 for tools. |
Lo-Fi Version | Time is now: 3rd May 2024 - 08:17 AM |
