Horizontal sail panel trim piece, How do you get it off ? |
jim_hoyland |
Sep 27 2014, 08:25 PM
Get that VIN ? Group: Members Posts: 9,283 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
How do you detach that trim piece below the sail vinyl ?
altitude411 |
Sep 27 2014, 08:38 PM
I drove my 6 into a tree Group: Members Posts: 1,306 Joined: 21-September 14 From: montana Member No.: 17,932 Region Association: Rocky Mountains |
How do you detach that trim piece below the sail vinyl ? Pull (IMG:style_emoticons/default/biggrin.gif) Seriously, if you reach up under the rear wheel well you can feel the clips (4 I believe) that just push in through round holes drilled in the sail panel. Push from the inside on the clips while pulling the trim piece and they should just pop out. |
bdstone914 |
Sep 27 2014, 08:48 PM
bdstone914 Group: Members Posts: 4,517 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
How do you detach that trim piece below the sail vinyl ? It has four spring clips that attach it. If can can get a couple of putty knives on each side of the clip you can carefully pry them off without bending the trim. Attached thumbnail(s) |
altitude411 |
Sep 27 2014, 08:53 PM
Now you know what the clips look like & here's a photo of the hole locations... if you push from inside wheel well and gently pull trim they'll pop off with no chance of scratching the paint or damage to the sail trim.
rhodyguy |
Sep 28 2014, 12:29 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,076 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
I would'nt use metal putty kniveS. Get 2 of the cheap plastic ones. One on each side of the push in clips.
JawjaPorsche |
Sep 28 2014, 01:12 PM
See how to replace sail vinyl webpage I made. AA has brand new clips if yours are fried. See page below.
http://76.162.11.251/tuck/sailvinyl.htm Attached image(s) |
malcolm2 |
Sep 29 2014, 07:56 AM
Advanced Member Group: Members Posts: 2,745 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
Clips are available too. They may break or be very rusty when you get them off. I recently saw them on Sierra Madre. As mentioned, work hard to NOT bend the trim
part # 999.591.326.01 door trim clip (65-98) Not under the 914 catalog. It seems like every car but the 914 is listed. Cheapest thing I might every buy for my car $0.96 each |
Lo-Fi Version | Time is now: 12th May 2024 - 08:18 AM |
