QUOTE(jim_hoyland @ Sep 27 2014, 08:25 PM)
How do you detach that trim piece below the sail vinyl ?
Pull
Seriously, if you reach up under the rear wheel well you can feel the clips (4 I believe) that just push in through round holes drilled in the sail panel. Push from the inside on the clips while pulling the trim piece and they should just pop out.
