Fog lights not working, calling all electricians |
malcolm2 |
Sep 28 2014, 02:26 PM
Advanced Member Group: Members Posts: 2,745 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
OK, I know enough about elec. to test a few things so here is what I found once home from Okteenerfest.
Fog lights, driving lights, whatever you want to call them just quit working. The pull knob lights up I get 12v in the front trunk at the connection from the main harness. (that is with the connection separated) {with all wire connected, I get no reading} Grounds have continuity there too. I did not get 12 volts once I took the light apart, not the bulb holder, just the light was apart and I used an alligator clip to ground it. No volts. If I remove the alligator clip from the hanging light in the picture below and put the red lead of the VM on the white/ylw wire at the bulb holder THEN the black lead of the VM to a bolt on the car..... I get 12 volts. So with the bulb holder or the complete fixture assembled and grounded I get nothing. What is going wrong here? |
malcolm2 |
Sep 29 2014, 06:16 PM
My guess on operation: When turned on and on low beam (OEM design) the relay activates (12v across 86 & 85) coil magnetizes and pulls the arm down to sends 12 volts thru 87.
knob in or high beams on and we have no path from 30 to 87 cause you loose the magnet and the spring opens the circuit and the lights go out. so the WH/ylw wire comes from 87? |
Lo-Fi Version | Time is now: 17th May 2024 - 07:22 PM |
