Door Panel Reconstruction, Passenger Side |
EdwardBlume |
Sep 28 2014, 07:31 PM
The passenger arm rest has an upper bolt in the door, a lower bolt in the door, and then two more lower bolts lined up.
It looks like the last two bolts are fixed in the door panel. Does anyone know how these are fixed to the door panels? Any pictures? Thanks, R |
rjames |
Sep 28 2014, 08:40 PM
I'm made of metal Group: Members Posts: 3,924 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
The passenger arm rest has an upper bolt in the door, a lower bolt in the door, and then two more lower bolts lined up. It looks like the last two bolts are fixed in the door panel. Does anyone know how these are fixed to the door panels? Any pictures? Thanks, R On my '75, the two lower right bolts went directly into the metal of the door. But I wouldn't be surprised if this wasn't correct. Taking off the panel to look is easy though. Just remove all the armrest bolts. The interior door handle and window crank (1 screw for each), carefully pop the clips on the outer edge of the panel and then slide the whole panel upwards to remove. Armed with replacement vynil and a staple gun, they are fairly easy to redo. |
bluhun |
Sep 28 2014, 10:10 PM
Member Group: Members Posts: 91 Joined: 23-January 06 From: San Rafael, CA Member No.: 5,464 Region Association: Northern California |
The passenger arm rest has an upper bolt in the door, a lower bolt in the door, and then two more lower bolts lined up. It looks like the last two bolts are fixed in the door panel. Does anyone know how these are fixed to the door panels? Any pictures? Thanks, R There are a couple of nuts attached to the backside of the door panel. |
EdwardBlume |
Sep 28 2014, 11:07 PM
The passenger arm rest has an upper bolt in the door, a lower bolt in the door, and then two more lower bolts lined up. It looks like the last two bolts are fixed in the door panel. Does anyone know how these are fixed to the door panels? Any pictures? Thanks, R There are a couple of nuts attached to the backside of the door panel. Thanks. How is it attached? |
Kansas 914 |
Sep 29 2014, 09:37 AM
Advanced Member Group: Members Posts: 2,999 Joined: 1-March 03 From: Durango, Colorado Member No.: 373 Region Association: Rocky Mountains |
The passenger arm rest has an upper bolt in the door, a lower bolt in the door, and then two more lower bolts lined up. It looks like the last two bolts are fixed in the door panel. Does anyone know how these are fixed to the door panels? Any pictures? Thanks, R There are a couple of nuts attached to the backside of the door panel. Thanks. How is it attached? I thought it was a special nut with a clip on it? Like some kind of a speed nut. |
StratPlayer |
Sep 29 2014, 03:49 PM
StratPlayer Group: Members Posts: 3,275 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
It's a nut that slides into a clip that is held on to the door using pressure, male part of the clip slips into a slot on both sides of the clip. That's on a late model
EdwardBlume |
Sep 29 2014, 09:45 PM
Anyone selling these 2 nuts and clips? I'm in need.
johannes |
Sep 30 2014, 05:15 AM
Club Porsche 914 France President Group: Members Posts: 3,084 Joined: 13-January 06 From: France Member No.: 5,409 Region Association: France |
rick 918-S |
Sep 30 2014, 06:59 AM
Hey nice rack! -Celette Group: Members Posts: 20,443 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
PM sent to Rob. I think I have a junk door panel with the clips in them. Unless you need to whole panel due to damage. I may have a usable core.
EdwardBlume |
Sep 30 2014, 07:18 AM
Perfect pictures. Thank you. |
EdwardBlume |
Sep 30 2014, 07:20 AM
PM sent to Rob. I think I have a junk door panel with the clips in them. Unless you need to whole panel due to damage. I may have a usable core. Thanks Rick! You rock. Here is what I'm looking for... the two black nut / clips in the panel. Thanks! Attached image(s) |
Dave_Darling |
Sep 30 2014, 12:44 PM
914 Idiot Group: Members Posts: 14,982 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
If those are the same square nuts with a C-shaped clamp over them that go into the door webs, I should have a whole baggie of them. I *think* I can find it... You can drop by or I can meet you somewhere and give you a handful.
I'll PM after I find them. --DD |
EdwardBlume |
Sep 30 2014, 12:59 PM
If those are the same square nuts with a C-shaped clamp over them that go into the door webs, I should have a whole baggie of them. I *think* I can find it... You can drop by or I can meet you somewhere and give you a handful. I'll PM after I find them. --DD If you have them.. great. Rick is looking for me too! Thx |
Lo-Fi Version | Time is now: 6th May 2024 - 06:45 PM |
