For those of you running a MSD ignition, What timing light do you use? |
stugray |
Sep 29 2014, 01:53 PM
I just ordered a MSD 6AL digital.
AND I recently purchased a variable timing light which I currently use to set my timing using the Flywheel zero degree mark. NOW I hear that the variable timing light will not work with the MSD due to the multiple sparks. I guess it throws off the light's ability to predict when the next pulse comes and firing the light "early" does not work correctly. With this nice "feature" that I just learned I am absolutely AMAZED that MSD did not think to just have a switch so that you can disable the multi-spark feature so you can set your timing. Anyone else find an elegant solution to this issue? The only thing i can think of is to reconfigure the ignition to work the standard way for setting the timing then switch it back to the MSD. What a PITA. Of course some will say "why not just use a regular light and use the stock timing marks"? That would be because I have a car with carbs, and I run at ~34 degrees advance at 3500 RPM. And that 34 degrees should vary a few degrees based on my altitude. I guess I can put new marks on the FW but measuring and marking with the engine in the car is also a PITA. |
Kansas 914 |
Sep 29 2014, 02:27 PM
I just ordered a MSD 6AL digital. AND I recently purchased a variable timing light which I currently use to set my timing using the Flywheel zero degree mark. NOW I hear that the variable timing light will not work with the MSD due to the multiple sparks. I guess it throws off the light's ability to predict when the next pulse comes and firing the light "early" does not work correctly. With this nice "feature" that I just learned I am absolutely AMAZED that MSD did not think to just have a switch so that you can disable the multi-spark feature so you can set your timing. Anyone else find an elegant solution to this issue? The only thing i can think of is to reconfigure the ignition to work the standard way for setting the timing then switch it back to the MSD. What a PITA. Of course some will say "why not just use a regular light and use the stock timing marks"? That would be because I have a car with carbs, and I run at ~34 degrees advance at 3500 RPM. And that 34 degrees should vary a few degrees based on my altitude. I guess I can put new marks on the FW but measuring and marking with the engine in the car is also a PITA. I am following this thread as I have the same situation. Car is running great now but tune ups are inevitable. Thanks Stu. |
Jeffs9146 |
Sep 29 2014, 02:49 PM
I have an MSD6al and used a variable timing light on my 3.0L-6 and it worked fine!
michael7810 |
Sep 29 2014, 03:47 PM
Senior Member Group: Members Posts: 1,081 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region |
My 30-year old Mac Tools variable timing light works with the MSD6.
stugray |
Sep 29 2014, 05:42 PM
I have an MSD6al and used a variable timing light on my 3.0L-6 and it worked fine! My 30-year old Mac Tools variable timing light works with the MSD6. Well maybe there is a chance it will still work, but a quick search shows that many people have trouble. Two thoughts: Maybe if you set the timing at high enough RPM, the MSD goes into single pulse mode, and the timing light "should" work, or Maybe the older variable timing lights (without microprocessors in them) work just fine. I guess I'll see later this week, I have one of the newer timing lights (dactron CP7529) And I also read mix results on whether the stock Tach will work with the MSD tach out signal. What was everyone's result? A- works just fine, or B- requires a tach-adapter? |
computers4kids |
Sep 29 2014, 09:18 PM
Love these little cars! Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
My harbor freight variable works fine with 6al.
wndsnd |
Sep 29 2014, 09:34 PM
You wanted a horse, but got a goat. Nobody wants a goat.... Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States |
You will newd a tach adapter unless you are running Tims worked over tach.
I have a new adapter you can have. PM me if you want it. |
stugray |
Oct 11 2014, 11:59 AM
Well I got the MSD installed and the timing light seems to work just fine.
However the Tach does not (as suggested above). So I hope to take advantage of wndsnd's offer (PM sent). |
Lo-Fi Version | Time is now: 17th May 2024 - 01:36 PM |
