Clutch fork end play |
rjames |
Sep 29 2014, 03:52 PM
I'm made of metal Group: Members Posts: 3,939 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
New flywheel is installed. Measured 3/4" of fork play when tranny was bolted up. Pulled tranny and Added a second washer to try and get it to the 1/2" spec.
Bolted it all back up and now have 1/4" of play. Is it ok to leave it or do I need to pull the tranny again and use a thinner washer? |
pilothyer |
Sep 29 2014, 04:53 PM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
Usually the added washer is to correct the geometry when the flywheel has been cut....I personally think you are ok but also would have been OK with just the one washer under the ball pivot. When the clutch cable is added and tightened the throw out will be in contact with the pressure plate fingers regardless of the free play so I would think the less the better.
Lo-Fi Version | Time is now: 23rd May 2024 - 11:52 PM |
