Clutch fork end play |
rjames |
Sep 29 2014, 03:52 PM
I'm made of metal Group: Members Posts: 3,933 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
New flywheel is installed. Measured 3/4" of fork play when tranny was bolted up. Pulled tranny and Added a second washer to try and get it to the 1/2" spec.
Bolted it all back up and now have 1/4" of play. Is it ok to leave it or do I need to pull the tranny again and use a thinner washer? |
Dr Evil |
Sep 29 2014, 05:48 PM
Send me your transmission! Group: Members Posts: 22,999 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Shimming the ball moves the clutch closer to the pressure plate and thus decreases the amount of travel to engage. What you did is fine. It is no prob to have the TOB touching the PP, that is how it should be. Just assure that your clutch pedal does not reach full PP disengagement before the pedal travel is completed or the cable will stretch. There is the adjustment on the pedal board for some limiting of the pedal arch.
Lo-Fi Version | Time is now: 18th May 2024 - 02:48 AM |
