My latest product idea, for Shift Linkage adjustment |
ChrisFoley |
Oct 1 2014, 10:03 AM
I am Tangerine Racing Group: Members Posts: 7,928 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
With all the enhancements available for our shift linkage, there's still one thing no one has ever addressed.
Adjusting the rotation so all three shift planes are where they belong relative to the lever assembly has always been a PITA, and is even more difficult with a Rennshift due to the small opening to access the pinch bolt. In addition, installing a more precise shift linkage assembly, like we all crave, makes precise adjustment even more critical. There should be a way to maintain alignment of the tunnel rod with the fork under the shift lever, and make precisely controlled rotation adjustments in a minute or less. An idea I've had on the back burner for a long time has finally reached the prototyping stage. (IMG:style_emoticons/default/idea.gif) I'm going to test a replacement Fork piece (914 424 171 01) machined from billet that incorporates a worm type adjuster against the splines of the tunnel rod. If it works it I believe it will be a game changer. (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smoke.gif) |
bigkensteele |
Oct 1 2014, 08:39 PM
Major Member Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States |
So, you really think that you are smarter than the engineers that gave us an unsealed battery sitting over a crucial structural component of the car, yet under a hole that water can enter freely?
You truly believe that your ideas could be better than those that gave us foam in the rear quarter taillight area and trunk lid frame? Of course those guys probably had two beers at every lunch, so you can't expect them to get everything right. Looking forward to see how this works out. |
ChrisFoley |
Oct 2 2014, 06:23 AM
Of course those guys probably had two beers at every lunch, so you can't expect them to get everything right. (IMG:style_emoticons/default/beerchug.gif) I've had the benefit of 30 years experience with what they created, and more than a few deep contemplations on the various "mistakes" made by the factory. (IMG:style_emoticons/default/smoke.gif) So if I actually do make an improvement that doesn't necessarily mean I'm smarter. (IMG:style_emoticons/default/shades.gif) |
worn |
Oct 2 2014, 02:02 PM
can't remember Group: Members Posts: 3,156 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Of course those guys probably had two beers at every lunch, so you can't expect them to get everything right. (IMG:style_emoticons/default/beerchug.gif) I've had the benefit of 30 years experience with what they created, and more than a few deep contemplations on the various "mistakes" made by the factory. (IMG:style_emoticons/default/smoke.gif) So if I actually do make an improvement that doesn't necessarily mean I'm smarter. (IMG:style_emoticons/default/shades.gif) Oh, no. Here you are mistaken. Yes it fuching well will! A worm screw to angle the assembly. What could be more elegant? We might say out of kindness that the engineers thought of this and were told it was over budget. Or we might say something else. Well done! |
Lo-Fi Version | Time is now: 21st May 2024 - 08:25 PM |
