My latest product idea, for Shift Linkage adjustment |
ChrisFoley |
Oct 1 2014, 10:03 AM
I am Tangerine Racing Group: Members Posts: 7,927 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
With all the enhancements available for our shift linkage, there's still one thing no one has ever addressed.
Adjusting the rotation so all three shift planes are where they belong relative to the lever assembly has always been a PITA, and is even more difficult with a Rennshift due to the small opening to access the pinch bolt. In addition, installing a more precise shift linkage assembly, like we all crave, makes precise adjustment even more critical. There should be a way to maintain alignment of the tunnel rod with the fork under the shift lever, and make precisely controlled rotation adjustments in a minute or less. An idea I've had on the back burner for a long time has finally reached the prototyping stage. (IMG:style_emoticons/default/idea.gif) I'm going to test a replacement Fork piece (914 424 171 01) machined from billet that incorporates a worm type adjuster against the splines of the tunnel rod. If it works it I believe it will be a game changer. (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smoke.gif) |
ChrisFoley |
Oct 3 2014, 01:42 PM
The first thing I tried didn't work well enough (too delicate) so after a little searching on the internet I found some components which I think can be readily adapted to my concept.
Here's an updated model showing the worm and gear pieces in the assembly. Support for the worm hasn't been modeled yet. I intend for the gear to be a light press on the splined shaft so it will act as a fore-aft locator, yet not rotate independently of the shaft - that is if I can successfully broach the id of the acetal gear with a piece of the splined shaft. |
Lo-Fi Version | Time is now: 21st May 2024 - 06:52 AM |
