My latest product idea, for Shift Linkage adjustment |
ChrisFoley |
Oct 1 2014, 10:03 AM
I am Tangerine Racing Group: Members Posts: 7,927 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
With all the enhancements available for our shift linkage, there's still one thing no one has ever addressed.
Adjusting the rotation so all three shift planes are where they belong relative to the lever assembly has always been a PITA, and is even more difficult with a Rennshift due to the small opening to access the pinch bolt. In addition, installing a more precise shift linkage assembly, like we all crave, makes precise adjustment even more critical. There should be a way to maintain alignment of the tunnel rod with the fork under the shift lever, and make precisely controlled rotation adjustments in a minute or less. An idea I've had on the back burner for a long time has finally reached the prototyping stage. (IMG:style_emoticons/default/idea.gif) I'm going to test a replacement Fork piece (914 424 171 01) machined from billet that incorporates a worm type adjuster against the splines of the tunnel rod. If it works it I believe it will be a game changer. (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smoke.gif) |
rjames |
Oct 17 2014, 02:21 PM
I'm made of metal Group: Members Posts: 3,933 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
QUOTE There should be a way to maintain alignment of the tunnel rod with the fork under the shift lever, and make precisely controlled rotation adjustments in a minute or less. Couldn't agree more. Thanks for working on this!! And I get the general concept of the design, but is the adjustment (in your prototype at least) made with the allen bolt? And if yes, what keeps the shift rod locked into position once the adjustment is made? |
Dave_Darling |
Oct 17 2014, 09:04 PM
914 Idiot Group: Members Posts: 14,990 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
And if yes, what keeps the shift rod locked into position once the adjustment is made? Looks like the bolt vertically through the coupler squeezes the coupler tight against the rod, just like stock piece. So that's what holds the adjustment, and the worm gear can provide fine adjustment after the pinch bolt is loosened. --DD |
ChrisFoley |
Oct 18 2014, 10:24 AM
Looks like the bolt vertically through the coupler squeezes the coupler tight against the rod, just like stock piece. So that's what holds the adjustment, and the worm gear can provide fine adjustment after the pinch bolt is loosened. --DD Exactly. As soon as I install the prototype I'll take pictures to show more clearly how it works. |
Lo-Fi Version | Time is now: 21st May 2024 - 04:56 AM |
