My latest product idea, for Shift Linkage adjustment |
ChrisFoley |
Oct 1 2014, 10:03 AM
I am Tangerine Racing Group: Members Posts: 7,928 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
With all the enhancements available for our shift linkage, there's still one thing no one has ever addressed.
Adjusting the rotation so all three shift planes are where they belong relative to the lever assembly has always been a PITA, and is even more difficult with a Rennshift due to the small opening to access the pinch bolt. In addition, installing a more precise shift linkage assembly, like we all crave, makes precise adjustment even more critical. There should be a way to maintain alignment of the tunnel rod with the fork under the shift lever, and make precisely controlled rotation adjustments in a minute or less. An idea I've had on the back burner for a long time has finally reached the prototyping stage. (IMG:style_emoticons/default/idea.gif) I'm going to test a replacement Fork piece (914 424 171 01) machined from billet that incorporates a worm type adjuster against the splines of the tunnel rod. If it works it I believe it will be a game changer. (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smoke.gif) |
nihil44 |
Oct 19 2014, 03:37 AM
Member Group: Members Posts: 157 Joined: 28-January 12 From: Brisbane, Australia Member No.: 14,058 Region Association: None |
Chris,
Why not go metric instead of 3/16". All of Porsche is metric. Perhaps consider 4,5 or 6mm. Let's make working on our cars simple. What is simpler than metric? David |
ChrisFoley |
Oct 19 2014, 06:41 AM
Chris, Why not go metric instead of 3/16". All of Porsche is metric. Perhaps consider 4,5 or 6mm. Let's make working on our cars simple. What is simpler than metric? David I always look at metric options first, however I won't force the issue if it increases the cost. Production volume of an item like this doesn't justify an investment in custom made miniature worm gear pieces. This is what I found available - off the shelf - for a proper test of concept. Until my order arrived I didn't even know a hex pocket was molded into one end of the worm body. It simplifies the assembly compared to my original plan. So far I'm very encouraged by the results. Although the production component will undoubtedly be noticeably different from the prototype. |
Lo-Fi Version | Time is now: 21st May 2024 - 07:20 PM |
