My latest product idea, for Shift Linkage adjustment |
ChrisFoley |
Oct 1 2014, 10:03 AM
I am Tangerine Racing Group: Members Posts: 7,928 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
With all the enhancements available for our shift linkage, there's still one thing no one has ever addressed.
Adjusting the rotation so all three shift planes are where they belong relative to the lever assembly has always been a PITA, and is even more difficult with a Rennshift due to the small opening to access the pinch bolt. In addition, installing a more precise shift linkage assembly, like we all crave, makes precise adjustment even more critical. There should be a way to maintain alignment of the tunnel rod with the fork under the shift lever, and make precisely controlled rotation adjustments in a minute or less. An idea I've had on the back burner for a long time has finally reached the prototyping stage. (IMG:style_emoticons/default/idea.gif) I'm going to test a replacement Fork piece (914 424 171 01) machined from billet that incorporates a worm type adjuster against the splines of the tunnel rod. If it works it I believe it will be a game changer. (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smoke.gif) |
VaccaRabite |
Oct 21 2014, 07:56 PM
En Garde! Group: Admin Posts: 13,445 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
So in a car with a Renshifter, your firewall aft kit and shift console kit, what will this get me?
Will it improve shifting if I already have the shifter adjusted? Zach |
ChrisFoley |
Oct 21 2014, 08:19 PM
So in a car with a Renshifter, your firewall aft kit and shift console kit, what will this get me? Will it improve shifting if I already have the shifter adjusted? Zach This mechanism will help one find the best adjustment quickly and easily. Slight adjustments can be tested without fear of losing the baseline position. It will only improve your shifting if your current adjustment isn't as good as it can be. |
Lo-Fi Version | Time is now: 21st May 2024 - 01:24 PM |
