Changing transmission mounts, Query about the front mounts |
porschefile2010 |
Oct 1 2014, 01:46 PM
Member Group: Members Posts: 228 Joined: 26-May 11 From: Whangaparaoa, New Zealand Member No.: 13,118 Region Association: Australia and New Zealand |
Hi. I have decided to change out both my transmission mounts and had planned to lift the car on to blocks, take the weight of the engine, lower it and remove the rear mounts. But it seems that I should also at least loosen the front mount cross bar so that it won't stress when I lower the transmission end of the engine. Is that correct?
Also are there any tricks I should know about that will reduce the aggro level. Thanks Richard |
Lo-Fi Version | Time is now: 29th May 2024 - 08:49 PM |
