Wiring Harness - hard to find, 75 VW Van Alternator Wiring Harness |
tracks914 |
Oct 3 2014, 08:18 AM
Canadian Member Group: Benefactors Posts: 2,083 Joined: 15-January 03 From: Timmins, Ontario, Canada Member No.: 153 Region Association: None |
Long story short. Local guy goes to boost his 75 VW Van. Hooks the cables up wrong, burns the alternator, voltage regulator and wiring harness. Almost looses the whole van. (IMG:style_emoticons/default/blink.gif)
Found a new voltage regulator and alternator (only 55amp) but where can I find a matching harness? This one has (3 plug connector to 3 plug connector) and large + wire but also has 2 extra wires at one end, (one + and one -) than my any of my 914's had. ??? Any one? Attached thumbnail(s) |
Cap'n Krusty |
Oct 3 2014, 08:39 AM
I may be able to get you one, but I'd probably have to find it in a boneyard and remove it from a vehicle. Major time could be involved. You have to have those 2 pigtails, and they're not (+) and (-). If you can't find one elsewhere, let me know.
The Cap'n |
76-914 |
Oct 3 2014, 08:56 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,504 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Go here https://groups.yahoo.com/neo/groups/subaruvanagon/info then ask Tom (tomvanagon, the moderator) if he has one. He just completed his 486th VW Bus to Subaru converted harness so I'll bet he has shit loads.
smokey |
Oct 3 2014, 06:49 PM
Senior Member Group: Members Posts: 533 Joined: 15-June 07 From: Freedom Ca Member No.: 7,816 Region Association: None |
High performance house
Red wood city . Kinda pricy |
914Sixer |
Oct 3 2014, 07:08 PM
914 Guru Group: Members Posts: 8,886 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Check theSamba. There is a person making new ones in the classified for vans and 914. I have a NOS 021.971.349D. It is a little different.
JeffBowlsby |
Oct 4 2014, 08:34 AM
914 Wiring Harnesses Group: Members Posts: 8,510 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Send your crusty one to me, I'll duplicate it.
tracks914 |
Oct 5 2014, 09:04 AM
tracks914 |
Oct 5 2014, 09:05 AM
Send your crusty one to me, I'll duplicate it. I can make my own pretty easy, just was hoping to find on online...easier. (IMG:style_emoticons/default/smile.gif) |
tracks914 |
Oct 15 2014, 10:25 AM
Well I took my 914 harness, spliced in the different wires from the VW van harness, installed the new voltage regulator and new alternator. Worked like a charm, then parked the van in the garage and pulled the battery for the owner. Tucked it in for winter.
BTW the longer power cable for the van (with an auto tranny), actually had a ~14" splice in it from the factory. Appears they used the basic 914 harness, added a couple of wires and made one cable longer. Who knew? |
Lo-Fi Version | Time is now: 20th May 2024 - 07:09 PM |
