turbine engine setup for 5k, is this for real |
thelogo |
Oct 6 2014, 02:53 PM
Senior Member Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
http://m.ebay.com/itm/301333942262
Somebody post the photo from this link if they know how ............ I always thought I would see someone's car with this setup here Before I saw it anywhere else. I know dodge experimented with this in the 60 s right But how viable is this power plant And how much would be involved in , money wise $$$ To do this installation.. I'm thinkin a lot. |
Oct 6 2014, 03:02 PM
Sleepin |
Oct 6 2014, 03:19 PM
Advanced Member Group: Members Posts: 3,647 Joined: 20-November 07 From: Grand Junction, Co. Member No.: 8,357 Region Association: Rocky Mountains |
Limo powerplant.
fixer34 |
Oct 6 2014, 03:41 PM
Senior Member Group: Members Posts: 1,085 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest |
I put this in the 'Just because you CAN do something doesn't mean you SHOULD do it...' category.
rgalla9146 |
Oct 6 2014, 04:03 PM
Advanced Member Group: Members Posts: 4,559 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
SLITS |
Oct 6 2014, 04:10 PM
STP Racing pulled it off at the Brickyard.
busmech |
Oct 6 2014, 05:36 PM
Member Group: Members Posts: 68 Joined: 12-April 09 From: Daly City Ca Member No.: 10,258 Region Association: Northern California |
There is one problem, the exhaust is going forward as built.
http://www.jetpower.co.uk/gtp70_gallery.htm I remember having a Car and Driver with a Vette powered by P&W PT6. Built by Granitelle. It idled at 60MPH and at the 1/4 mile left 2 black streeks for 1,200 feet. You can run them on about anything, but this one would not work for a 914 maybe a VW but you would burn the paint off the car behind you. |
veekry9 |
Oct 6 2014, 06:28 PM
OldMember Group: Retired Members Posts: 3,068 Joined: 17-June 13 From: TO Member No.: 16,025 Region Association: Canada |
https://www.youtube.com/watch?v=b2A5ijU3Ivs https://www.youtube.com/watch?v=4itFz7EVGqA http://www.granatellimotorsports.com/ http://jalopnik.com/5979348/forgotten-cars...urbine-cars-too More research needed,lot of BS spouted. http://en.wikipedia.org/wiki/STP-Paxton_Turbocar http://blog.hemmings.com/index.php/2014/06...ads-to-auction/ |
Elliot Cannon |
Oct 6 2014, 06:38 PM
Chrysler tried it back in the early sixties. They leased them to a few families around the country to try it out. There was one close to my house. And, of course, Leno has one. (IMG:style_emoticons/default/biggrin.gif)
FourBlades |
Oct 6 2014, 07:10 PM
From Wreck to Rockin Group: Members Posts: 2,054 Joined: 3-December 07 From: Brevard, FL Member No.: 8,414 Region Association: South East States |
Mike Bellis |
Oct 6 2014, 07:15 PM
I see my next donor motor... (IMG:style_emoticons/default/idea.gif)
I bet it's loud! (IMG:style_emoticons/default/happy11.gif) |
veekry9 |
Oct 6 2014, 08:35 PM
Roads? Where we're going,we don't need Roads Gas Turbine generator charges batteries runs electric motors. Intrinsic losses mount. Way Neato tho. Anyone interested in an attempt to do better what Rover and Chrysler did? Deep pocket develops hole. New materials available today may make feasible a more efficient turbine and drive. |
Mark Henry |
Oct 6 2014, 08:58 PM
mapguy |
Oct 7 2014, 12:05 AM
Freelance Generalist Group: Members Posts: 90 Joined: 31-January 14 From: Inland Empire, CA Member No.: 16,945 Region Association: Southern California |
One word: Sandrail. I bet you'd be the only guy at the dunes with one. At least until you sucked sand into the blades.
I wouldn't want to be around for that. (IMG:style_emoticons/default/blowup.gif) |
maf914 |
Oct 7 2014, 05:35 AM
Two words: M1 Abram.
From Wikipedia: The M1 Abrams' powertrain comprises a 1,500 shaft horsepower (1,100 kW) Honeywell AGT 1500 (originally made by Lycoming) multi-fuel gas turbine, and a six speed (four forward, two reverse) Allison X-1100-3B Hydro-Kinetic automatic transmission, giving it a governed top speed of 45 mph (72 km/h) on paved roads, and 30 mph (48 km/h) cross-country. With the engine governor removed, speeds of around 60 mph (97 km/h) are possible on an improved surface; however, damage to the drivetrain (especially to the tracks) and an increased risk of injuries to the crew can occur at speeds above 45 mph (72 km/h). The tank was built around this engine[59] and it is multifuel capable; meaning that it can be powered with diesel, kerosene, any grade of motor gasoline, and jet fuel (such as JP-4 or JP-8). For logistical reasons, JP-8 is the US military's universal fuel powering both aircraft and vehicle fleets. On the other hand, Australian M1A1 AIM SA burn diesel fuel, since the use of JP-8 is less common in the Australian Army. Attached image(s) |
ripper911 |
Oct 7 2014, 05:59 AM
corde pulsum tangite Group: Members Posts: 2,920 Joined: 25-April 10 From: Powder Springs, GA Member No.: 11,654 Region Association: South East States |
It should fit in a 914.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i921.photobucket.com-11654-1412683165.1.jpg) |
rgalla9146 |
Oct 7 2014, 06:08 AM
Two words: M1 Abram. From Wikipedia: The M1 Abrams' powertrain comprises a 1,500 shaft horsepower (1,100 kW) Honeywell AGT 1500 (originally made by Lycoming) multi-fuel gas turbine, and a six speed (four forward, two reverse) Allison X-1100-3B Hydro-Kinetic automatic transmission, giving it a governed top speed of 45 mph (72 km/h) on paved roads, and 30 mph (48 km/h) cross-country. With the engine governor removed, speeds of around 60 mph (97 km/h) are possible on an improved surface; however, damage to the drivetrain (especially to the tracks) and an increased risk of injuries to the crew can occur at speeds above 45 mph (72 km/h). The tank was built around this engine[59] and it is multifuel capable; meaning that it can be powered with diesel, kerosene, any grade of motor gasoline, and jet fuel (such as JP-4 or JP-8). For logistical reasons, JP-8 is the US military's universal fuel powering both aircraft and vehicle fleets. On the other hand, Australian M1A1 AIM SA burn diesel fuel, since the use of JP-8 is less common in the Australian Army. It will require a muffler the size of the car. |
veekry9 |
Oct 7 2014, 07:05 AM
http://www.avonaero.com/garrett70.htm Two would fit nicely in a helicopter. A miniature turbine EV has got to be more efficient than a piston engine EV. |
mbseto |
Oct 7 2014, 07:17 AM
Senior Member Group: Members Posts: 1,253 Joined: 6-August 14 From: Cincy Member No.: 17,743 Region Association: North East States |
...until you factor in maintenance costs.
CptTripps |
Oct 7 2014, 08:22 AM
:: Punch and Pie :: Group: Members Posts: 3,584 Joined: 26-December 04 From: Mentor, OH Member No.: 3,342 Region Association: Upper MidWest |
I'd go Electric before I'd go Turbine...
...and I'd likely blow a hobo in a truck-stop bathroom before either. |
Lo-Fi Version | Time is now: 20th May 2024 - 10:28 PM |
