Am I missing a bolt here? |
CptTripps |
Jan 28 2005, 06:02 PM
:: Punch and Pie :: Group: Members Posts: 3,584 Joined: 26-December 04 From: Mentor, OH Member No.: 3,342 Region Association: Upper MidWest |
I'm about to cut the floor out, and I was looking for somewhere to put the jack stands when I saw this...
There isn't one in the other side either. Am I missing a few screws? (Other than the ones in my head...) Attached image(s) |
eeyore |
Jan 28 2005, 06:04 PM
Important. 1 of 6 that hold on the front suspension.
CptTripps |
Jan 28 2005, 06:09 PM
::: great :::
I'm missing that one, and it's twin on the other side. Do those come loose often, or did I just find another PO mistake? ::: oiy ::: |
ClayPerrine |
Jan 28 2005, 06:12 PM
Life's been good to me so far..... Group: Admin Posts: 15,425 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
DAPO... the bolts hold the rear of the gravel pan on, but they also hold the front suspension on the car.
Replace them ASAP. |
dlee1967 |
Jan 28 2005, 06:14 PM
V8Lurker Group: Members Posts: 540 Joined: 20-February 03 From: Splendora, TX Member No.: 327 Region Association: None |
Someone took off the splashpan that protects the steering rack and master cylinder. You will also see two more threaded holes for two 8mm bolts (parallel to the ground). DLee
SpecialK |
Jan 28 2005, 06:20 PM
aircraft surgeon Group: Benefactors Posts: 3,211 Joined: 15-March 04 From: Pacific, MO Member No.: 1,797 |
I've got the same bolt missing off of the driver's side.....except the bolts still there, just the head missing......gonna be fun getting that one out (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif)
Rhodes71/914 |
Jan 28 2005, 06:46 PM
Glacier Group: Members Posts: 1,374 Joined: 8-August 04 From: End of the Road, Alaska Member No.: 2,482 |
Yep, mine were missing as well. Only drove my car around the block a couple of times before I decided to do some brake work. Posted the same pic as you after I crawled around and looked under there. I got the bolts and pan off a donor car.
McMark |
Jan 28 2005, 07:03 PM
Interesting place for the fuel pump.
CptTripps |
Jan 28 2005, 07:05 PM
Yeah, I noticed that too...Tell me THAT isn't vulnerable! I'll be moving it up inside when I re-run the lines this weekend.
jim912928 |
Jan 28 2005, 07:18 PM
Senior Member Group: Members Posts: 1,485 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest |
geez...all you put those bolts in! You should:
1. get the bolts 2. get a pan to protect that stuff 3. fuel filter and fuel pump should be up above and under the tank..that is where they put it in 75/76 model years. Good thing you are going through this thing! |
CptTripps |
Jan 28 2005, 07:22 PM
Yeah. I'm starting to be real glad I'm taking the time to go through the whole thing. I'll be doing more than I thought I would...but that's half the fun...right? Actually, I'm really enjoying this. The plan is to drive it to WCC...we'll see how that goes. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
Chris H. |
Jan 28 2005, 07:57 PM
Senior Member Group: Members Posts: 4,029 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
What size are those bolts? I might have some.
xsboost90 |
Jan 28 2005, 08:07 PM
Senior Member Group: Members Posts: 1,393 Joined: 2-August 04 From: cincinnati Member No.: 2,432 |
can you tell me if mines still there? (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif)
Cap'n Krusty |
Jan 28 2005, 08:24 PM
Scary? Post 1974 911s have it there .................... The Cap'n |
McMark |
Jan 28 2005, 09:49 PM
Yeah, I don't really have a problem with the fuel pump there as long as it's securely mounted and you have the gravel pan in place.
xsboost90, looks like your bolts are in place, but your drivers side horn is in the wrong place. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
jim912928 |
Feb 4 2005, 10:45 AM
for anybody that chatted in this thread about missing the steering rack cover/pan....just ran across this one up on ebay today:
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...&category=33589 For those that need to find this hard part. Jim |
Lo-Fi Version | Time is now: 2nd May 2024 - 07:00 AM |
