help me I.d. This wire connector, 75 914 in trunk , not sure what this would go to |
DRPHIL914 |
Oct 8 2014, 07:17 AM
I also do not have a wire for the right rear trunk light . Not sure if this could be the missing connector? Or would it be for a center rear reflector/light?.
Attached thumbnail(s) |
biosurfer1 |
Oct 8 2014, 07:45 AM
Teener fo Life! Group: Members Posts: 3,020 Joined: 3-August 03 From: Roseville, CA Member No.: 977 Region Association: Northern California |
Not sure about the connector but the center reflector for the 914 did not light up so it wouldn't be that unless it was something very custom.
DRPHIL914 |
Oct 8 2014, 07:59 AM
all my lights work except for the one license plate light. i went to replace the bulb and there was no wiring behind there on that side. there are two wires going into the back center wall of the trunk but it looks like they both go to the left side light, which works fine. Should i jump the left side and run a wire from the left to the right side?
Krieger |
Oct 8 2014, 08:00 AM
Advanced Member Group: Members Posts: 4,714 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
That is for a relay to plug into for emission purposes. I think a wire from the cat plugs into that relay. It has been off my car for a while. I use the wires in that plug for something else now
DRPHIL914 |
Oct 8 2014, 08:04 AM
That is for a relay to plug into for emission purposes. I think a wire from the cat plugs into that relay. It has been off my car for a while. I use the wires in that plug for something else now what do you use them for now? and what would each color wire be for? |
Krieger |
Oct 8 2014, 08:47 AM
I have an O2 sensor I put in the exhaust and a Air fuel meter I put inside to check things out every couple of years.
Krieger |
Oct 8 2014, 08:49 AM
I not sure but I think if the catalytic converter overheats the relay that your missing turns the CAT light on the dash.
Cap'n Krusty |
Oct 8 2014, 09:59 AM
You could, if you were really interested, look for the plug in the wiring diagram. You can probably find the wire colors and look for a group that matches.
The Cap'n |
Oct 8 2014, 10:06 AM
I not sure but I think if the catalytic converter overheats the relay that your missing turns the CAT light on the dash. (IMG:style_emoticons/default/agree.gif) |
Lo-Fi Version | Time is now: 20th May 2024 - 09:44 PM |
