taco plate wire path |
malcolm2 |
Oct 11 2014, 09:08 AM
Advanced Member Group: Members Posts: 2,745 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
I got a oil temp taco plate set up out of a JY car. Wire, sender, cover, plate, clips etc...
I am ready to change my oil and put this thing on. It was probably last summer that I carefully removed it from a 73. I can't remember the path of the wire. There is a connector on my car's harness that is at the battery. I believe that is the connection. And a bunch in the tunnel, maybe one behind the dash. I will check all those. But from the taco plate to the 1st connector is only semi-obvious. (IMG:style_emoticons/default/confused24.gif) Pictures would be great, if anyone has them. Hind sight.... take pictures at the JY. Thanks, Clark |
Oct 11 2014, 11:19 AM
It comes out of the plate, goes across the front of the engine near the motor mounts (hint: be careful not to squash the wire flat, you get a full-hot reading all the time!) to a stand-off on one of the oil cooler bracket bolts. Then through the engine tin to the connector under the battery that you found.
--DD |
malcolm2 |
Oct 11 2014, 12:04 PM
It comes out of the plate, goes across the front of the engine near the motor mounts (hint: be careful not to squash the wire flat, you get a full-hot reading all the time!) to a stand-off on one of the oil cooler bracket bolts. Then through the engine tin to the connector under the battery that you found. --DD Yes, I now remember a bit. There is a clip that goes on that standoff. |
malcolm2 |
Oct 14 2014, 08:13 PM
In case anyone runs across this post.... I found THIS POST
It has helped for sure. pictures too. (IMG:style_emoticons/default/piratenanner.gif) Clark |
bdstone914 |
Oct 14 2014, 08:41 PM
In case anyone runs across this post.... I found THIS POST It has helped for sure. pictures too. (IMG:style_emoticons/default/piratenanner.gif) Clark There are two wire standoffs for the taco plate wire. The other one bolts to one of the oil filter flange studs. You can see it in a picture in McMar k s thread. |
Oct 14 2014, 08:59 PM
Shoot, that's right! I forgot about that one...
--DD |
Lo-Fi Version | Time is now: 20th May 2024 - 08:04 PM |
