I got a oil temp taco plate set up out of a JY car. Wire, sender, cover, plate, clips etc...
I am ready to change my oil and put this thing on. It was probably last summer that I carefully removed it from a 73. I can't remember the path of the wire. There is a connector on my car's harness that is at the battery. I believe that is the connection. And a bunch in the tunnel, maybe one behind the dash. I will check all those.
But from the taco plate to the 1st connector is only semi-obvious.
Pictures would be great, if anyone has them. Hind sight.... take pictures at the JY.
Thanks,
Clark
