Sway bar change mid 1974, What is the difference? |
Jmkorfha |
Oct 12 2014, 01:02 PM
I'm not a singing grandpa. Group: Members Posts: 58 Joined: 26-October 13 From: Austin, Mn Member No.: 16,569 Region Association: Upper MidWest |
Does anyone know what the change was in the front sway bar in mid 1974? I have tried searching to no avail. Words would be great, pictures fantastic. I ask only out of curiosity. I believe that the 911s mounted the bar low around that time.(?)
bdstone914 |
Oct 12 2014, 01:08 PM
QUOTE Does anyone know what the change was in the front sway bar in mid 1974? I have tried searching to no avail. Words would be great, pictures fantastic. I ask only out of curiosity. I believe that the 911s mounted the bar low around that time.(?) I think all front sway bars are the same. 911 Went to an under body sway Bar in 74. Completely did decent bar. |
Luke M |
Oct 12 2014, 01:11 PM
Senior Member Group: Members Posts: 1,372 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
As far as I know there's no change in the way the bar mounts to a 914.
70 - 76 the front bar goes/mounts through the chassis under the gas tank. Only difference is the rear mount bracket from 70-74 then changed in 75-76. The 911 front is all different as the early cars where through the chassis then switched to the under car mount. I don't recall the year it switched over but maybe 75 ? |
Jmkorfha |
Oct 12 2014, 01:17 PM
The reason I'm curious is that the non stock style Addco sway bar kits for the front changes in mid 74. The rear is the same for all years. Addco bars tempting at only $130 each. Anyone used one?
Johny Blackstain |
Oct 12 2014, 01:24 PM
Walnut Elite Stratocaster player Group: Members Posts: 3,434 Joined: 5-December 06 From: The Shenandoah River Member No.: 7,318 Region Association: MidAtlantic Region |
kid914 |
Oct 12 2014, 02:07 PM
ALWAYS lead...NEVER follow!!!! Group: Members Posts: 2,534 Joined: 9-March 11 From: Canada Member No.: 12,811 Region Association: Canada |
Thanks for the heads up. I just looked them up. interested as well at that price.
(IMG:style_emoticons/default/popcorn[1].gif) |
McMark |
Oct 12 2014, 02:19 PM
Stock front sway bars were the same on all years.
Jmkorfha |
Oct 12 2014, 02:42 PM
Stock front sway bars were the same on all years. I have also concluded the same. As I have been researching this afternoon, I see that the Addco bar is mounted under the front like the 75 and later 911s. I am guessing that the lower cover is different after the fuel pump move? Perhaps the later addco bar has to miss the different cover where the through the body stock bar is unchanged. |
McMark |
Oct 12 2014, 02:54 PM
I wouldn't buy either of the sways bars listed (PN 114 or 167).
Jmkorfha |
Oct 12 2014, 06:25 PM
maf914 |
Oct 13 2014, 05:56 AM
Here the installation instructions for the Addco 167 front sway bar. Check the bracket and method used at the A-arm drop link connection. No thanks.
Years ago, I installed Addco bars on a 1992 Nissan and was pleased with the results, but I don't like the looks of the 914 installation. On the Jegs link, click on the instructions tab. http://addco.s3.amazonaws.com/wp-content/u...2012/03/167.pdf http://www.jegs.com/i/ADDCO/020/114/10002/...arentProductId= Also check the instructions for the rear bar, Addco 974. The attachment to the rear trailing arm is interesting. http://www.jegs.com/i/ADDCO/020/974/10002/...arentProductId= |
Jmkorfha |
Oct 13 2014, 09:17 AM
The attachment is certainly a more "common" attachment and may actually be more compact than the line drawing seems. I wonder what it does for clearance. Also, if it stresses the control arm bushings with side to side force. Seems like it should be easy to engineer a better attachment. How does the 75 911 attach at the control arms? |
Lo-Fi Version | Time is now: 16th May 2024 - 07:26 PM |
