914/6 Ignition Switch |
McMark |
Oct 12 2014, 02:16 PM
I've been collecting parts for my conversion and I just got my 911 ignition switch (P/N 911.613.011.01). It's got the correct silver center. I have an original 914/6 steering column, but the steering lock arm doesn't fit into the bracket into the column. I know this is a 'normal' thing and removing some material will make everything work fine. But since I'm mostly insane, I'd like to see pics of a real 914/6 ignition switch to compare and replicate if possible.
Anyone have pictures? Even better, anyone have one they can measure? And what about the original unit part number? What's that? The number in the PET doesn't seem to match the numbers I've seen. Attached image(s) |
SirAndy |
Oct 12 2014, 03:51 PM
Resident German Group: Admin Posts: 41,606 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Yepp, i had to shave off some material from the 911 switch i used.
(IMG:style_emoticons/default/smash.gif) |
SixerJ |
Oct 12 2014, 03:56 PM
Member Group: Members Posts: 448 Joined: 24-June 13 From: UK Member No.: 16,042 Region Association: England |
Hi Mark, does this help?
I bought a complete -6 lock set (or at least that's what it was advertised as) of the bay about a year ago - Sir Andy? Let me know if you need more pictures Jon Attached thumbnail(s) |
SixerJ |
Oct 12 2014, 04:01 PM
McMark |
Oct 12 2014, 04:08 PM
SixerJ, THANKS! Can you take one more with the part number facing down?
SixerJ |
Oct 12 2014, 04:23 PM
sixnotfour |
Oct 12 2014, 07:17 PM
914 Wizard Group: Members Posts: 10,411 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
they added more material so the bolt actually secured the lock in position = hareder to remove... grind flat = done
914Sixer |
Oct 12 2014, 09:24 PM
914 Guru Group: Members Posts: 8,870 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
914-6 PET shows the lock assembly as 911.613.901.00. So the one you are using is a later one. There was one assembly for the 65-68 911 column, one for the 69-73 911 column and then 74-89.
McMark |
Oct 12 2014, 09:34 PM
Awesome! Now I can make mine look right.
grind flat = done You make it sound so easy. If only it was for the obsessive compulsive. (IMG:style_emoticons/default/unsure.gif) |
SixerJ |
Oct 13 2014, 09:09 AM
Mark,
Apologies for hijacking your thread, but could you take some detailed pictures of your genuine column with any relevant dimensions for the flat bracket position on the tube factory welding details, any other relevant dimensional information etc? I was thinking it would be useful to capture details of both the ignition lock and column in a single thread for those who we're thinking of building themselves a facsimile of the factory set up? Also those in the know regarding the exact differences (functionality of the switch and connectors) between the 911 switches and 914-6 would be useful to capture in a single place as well |
larryM |
Oct 16 2014, 09:21 PM
emoze Group: Members Posts: 891 Joined: 1-January 03 From: mid- California Member No.: 65 Region Association: Northern California |
notwithstanding all the perfection above
- if you are going to track the car with any of the sanctioned race clubs - (my experience per scca & vara) - it is generally required to disable ( remove or block) that interlock mechanism nobody wants a non-steerable missile coming down the track at them |
McMark |
Oct 21 2014, 12:21 PM
Pictures of the steering column. Let me know what else you need.
Attached image(s) |
Mark Henry |
Oct 21 2014, 01:01 PM
This is a lot of work...wasn't the '72 six just like a /4 with the key on the column?
Just asking because I don't need any help fueling my OCD on this point for my '74 /6 conversion. (IMG:style_emoticons/default/wink.gif) |
mepstein |
Oct 21 2014, 03:34 PM
914-6 GT in waiting Group: Members Posts: 19,239 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
This is a lot of work...wasn't the '72 six just like a /4 with the key on the column? Just asking because I don't need any help fueling my OCD on this point for my '74 /6 conversion. (IMG:style_emoticons/default/wink.gif) It is work and money. It's optional but if you like the look, go for it. |
biosurfer1 |
Oct 21 2014, 03:40 PM
Teener fo Life! Group: Members Posts: 3,020 Joined: 3-August 03 From: Roseville, CA Member No.: 977 Region Association: Northern California |
grind flat, throw away, grind flat, throw away, grind flat, throw away, grind flat = done You make it sound so easy. If only it was for the obsessive compulsive. (IMG:style_emoticons/default/unsure.gif) There, fixed it (IMG:style_emoticons/default/smile.gif) |
altitude411 |
Oct 21 2014, 04:32 PM
I drove my 6 into a tree Group: Members Posts: 1,306 Joined: 21-September 14 From: montana Member No.: 17,932 Region Association: Rocky Mountains |
What is this connection for? My '70 six does not have it...
Also does any know of a clamshell vendor or have one for sale? Mine would be repairable (epoxy/fiberglass/paint) but I would replace if possible. |
type47fan |
Oct 21 2014, 07:28 PM
It Looks Better In Person. . . Group: Members Posts: 860 Joined: 17-September 03 From: Carlsbad, CA Member No.: 1,170 Region Association: Southern California |
altitude411 |
Oct 21 2014, 07:54 PM
Ah, that makes sense. Good, I'm glad I don't have one! I hate those things. They always scare away the deer when I'm poach, er.... um, hunting. (IMG:style_emoticons/default/ar15.gif)
McMark |
Oct 21 2014, 08:08 PM
Also does any know of a clamshell vendor or have one for sale? Mine would be repairable (epoxy/fiberglass/paint) but I would replace if possible. DON'T buy the reproduction from Automobile Atlanta. It's a terrible 'reproduction' (if you can even call it that). (IMG:style_emoticons/default/sad.gif) |
altitude411 |
Oct 21 2014, 08:21 PM
Thanks for the heads up Mark, I'll keep shopping the e. (IMG:style_emoticons/default/popcorn[1].gif)
Lo-Fi Version | Time is now: 26th April 2024 - 11:18 AM |
