914/6 Ignition Switch |
McMark |
Oct 12 2014, 02:16 PM
I've been collecting parts for my conversion and I just got my 911 ignition switch (P/N 911.613.011.01). It's got the correct silver center. I have an original 914/6 steering column, but the steering lock arm doesn't fit into the bracket into the column. I know this is a 'normal' thing and removing some material will make everything work fine. But since I'm mostly insane, I'd like to see pics of a real 914/6 ignition switch to compare and replicate if possible.
Anyone have pictures? Even better, anyone have one they can measure? And what about the original unit part number? What's that? The number in the PET doesn't seem to match the numbers I've seen. Attached image(s) |
914Sixer |
Oct 12 2014, 09:24 PM
914 Guru Group: Members Posts: 8,876 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
914-6 PET shows the lock assembly as 911.613.901.00. So the one you are using is a later one. There was one assembly for the 65-68 911 column, one for the 69-73 911 column and then 74-89.
Lo-Fi Version | Time is now: 7th May 2024 - 05:22 PM |
