914/6 Ignition Switch |
McMark |
Oct 12 2014, 02:16 PM
I've been collecting parts for my conversion and I just got my 911 ignition switch (P/N 911.613.011.01). It's got the correct silver center. I have an original 914/6 steering column, but the steering lock arm doesn't fit into the bracket into the column. I know this is a 'normal' thing and removing some material will make everything work fine. But since I'm mostly insane, I'd like to see pics of a real 914/6 ignition switch to compare and replicate if possible.
Anyone have pictures? Even better, anyone have one they can measure? And what about the original unit part number? What's that? The number in the PET doesn't seem to match the numbers I've seen. Attached image(s) |
larryM |
Oct 16 2014, 09:21 PM
emoze Group: Members Posts: 891 Joined: 1-January 03 From: mid- California Member No.: 65 Region Association: Northern California |
notwithstanding all the perfection above
- if you are going to track the car with any of the sanctioned race clubs - (my experience per scca & vara) - it is generally required to disable ( remove or block) that interlock mechanism nobody wants a non-steerable missile coming down the track at them |
Lo-Fi Version | Time is now: 7th May 2024 - 01:48 PM |
