914/6 Ignition Switch |
McMark |
Oct 12 2014, 02:16 PM
I've been collecting parts for my conversion and I just got my 911 ignition switch (P/N 911.613.011.01). It's got the correct silver center. I have an original 914/6 steering column, but the steering lock arm doesn't fit into the bracket into the column. I know this is a 'normal' thing and removing some material will make everything work fine. But since I'm mostly insane, I'd like to see pics of a real 914/6 ignition switch to compare and replicate if possible.
Anyone have pictures? Even better, anyone have one they can measure? And what about the original unit part number? What's that? The number in the PET doesn't seem to match the numbers I've seen. Attached image(s) |
McMark |
Nov 26 2014, 03:41 PM
Got my switch modified by the machine shop. They took just a little too much off, but it's not going to make a difference in the installation. Only I will know. Well, and now all of you. But no one else. (IMG:style_emoticons/default/biggrin.gif)
Now to pull the tumblers and rekey it to my NOS key. (IMG:style_emoticons/default/drooley.gif) Attached image(s) |
SixerJ |
Nov 28 2014, 11:48 AM
Member Group: Members Posts: 448 Joined: 24-June 13 From: UK Member No.: 16,042 Region Association: England |
Got my switch modified by the machine shop. They took just a little too much off, but it's not going to make a difference in the installation. Only I will know. Well, and now all of you. But no one else. (IMG:style_emoticons/default/biggrin.gif) Now to pull the tumblers and rekey it to my NOS key. (IMG:style_emoticons/default/drooley.gif) Very cool, looks like they did a great job. I looked at my ignition and good door handles (all will be now odd) and decided that the ignition looked a PITA to re key in comparison to the other locks That said I only have to do the door handles as I will have no trunk, glove box and the hood pull will probably be used for the gas strut headlight kit. If I had all matching locks apart from the ignition I would be looking closely at it! Please post the steps required to for rekeying |
Lo-Fi Version | Time is now: 7th May 2024 - 11:58 AM |
