914/6 Ignition Switch |
McMark |
Oct 12 2014, 02:16 PM
I've been collecting parts for my conversion and I just got my 911 ignition switch (P/N 911.613.011.01). It's got the correct silver center. I have an original 914/6 steering column, but the steering lock arm doesn't fit into the bracket into the column. I know this is a 'normal' thing and removing some material will make everything work fine. But since I'm mostly insane, I'd like to see pics of a real 914/6 ignition switch to compare and replicate if possible.
Anyone have pictures? Even better, anyone have one they can measure? And what about the original unit part number? What's that? The number in the PET doesn't seem to match the numbers I've seen. Attached image(s) |
jkb944t |
Apr 15 2015, 02:47 PM
Member Group: Members Posts: 464 Joined: 17-January 05 From: Canton, OH Member No.: 3,459 Region Association: None |
If I understand your post correctly you simply removed the ignition switch from the steering column and relocated it to the left side on the dash. In doing that you forfeit the steering wheel locking feature but that doesn’t seem like that big of deal to me.
I’m not sure what part you were going to sell though. Do you have any other pictures or a more detailed procedure that you followed to do this conversion? Jeff B |
Lo-Fi Version | Time is now: 7th May 2024 - 11:43 AM |
