Window seal recovering question |
Joe Bob |
Oct 12 2014, 04:07 PM
Yeah, yeah.....I know it's a 911 cab. But you cheap bastards are the schizzle on DIY and or restoration questions. These seals are uber expensive.
They used to be black and cloth covered, the cloth has been sun bleached and now split and separating from the underlying rubber. If removed, do think it can be recovered? Attached thumbnail(s) |
Joe Bob |
Oct 12 2014, 04:08 PM
This the seal attached to the cab top frame and is at the rear of the front window.
Larmo63 |
Oct 13 2014, 12:23 AM
If the cloth just covers rubber, can you carefully strip it and just run the rubber?
Joe Bob |
Oct 13 2014, 09:59 AM
I had come to that conclusion while staring at them with a cuppa coffee.....thanks.
Mikey914 |
Oct 13 2014, 12:02 PM
The rubber man Group: Members Posts: 12,667 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
The seals are not really that expensive if you know where to get them (IMG:style_emoticons/default/biggrin.gif)
The cloth was a P/O trying to hide the seal had cracked. Looks like they glued a piece of velvet onto the seal. Good idea to save a few bucks! But eventually it will do exactly what you see. probably has crack in the inner seal. You may be able to recover. |
Joe Bob |
Oct 13 2014, 12:04 PM
And you're keeping the source of cheap replacement seals a secret? Gee thanks....
Cap'n Krusty |
Oct 13 2014, 12:06 PM
The seals are not really that expensive if you know where to get them (IMG:style_emoticons/default/biggrin.gif) The cloth was a P/O trying to hide the seal had cracked. Looks like they glued a piece of velvet onto the seal. Good idea to save a few bucks! But eventually it will do exactly what you see. probably has crack in the inner seal. You may be able to recover. Not true, unless hundreds, maybe even thousands, of CSOB 911 owners had the same idea. The Cap'n |
Mikey914 |
Oct 13 2014, 12:07 PM
And you're keeping the source of cheap replacement seals a secret? Gee thanks.... Look at the bottom od the signature on my post. (IMG:style_emoticons/default/smile.gif) And I prefer inexpensive, not cheap. There is a difference. |
Lo-Fi Version | Time is now: 16th May 2024 - 06:21 PM |
