What is the diameter? |
Larmo63 |
Oct 13 2014, 01:21 PM
What is the diameter of a stock rear 914-4 rotor?
pilothyer |
Oct 13 2014, 02:14 PM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
Oct 13 2014, 04:05 PM
Is that for the -4 or the -6? The -6 rotor is (very) slightly larger.
--DD |
pilothyer |
Oct 13 2014, 04:07 PM
I gave the dimension for the 6 banger.................. for the 914-4 it is 281.94mm or 11.1in. I edited my first reply to correct info given.
Larmo63 |
Oct 13 2014, 05:27 PM
Thank you
Cap'n Krusty |
Oct 13 2014, 06:46 PM
d=2r
You're welcome! The Cap'n |
stugray |
Oct 16 2014, 07:32 PM
I heard from a super-V racer at the track that karman ghia rotors will fit on a 914.
At first I thought "so what". He said you can order ghia rotors un-drilled and have them drilled for a 5 bolt pattern. Anyone else heard of that? I have a full set of 914 rotors laying around, but not a ghia set to compare them to. |
bdstone914 |
Oct 16 2014, 08:34 PM
Ghia ' s only had disc brakes on the front as I recall. So what would be the point over using them over 914 rotors?
And I don't know if any of them were hub centric. I looked up the part number for a Ghia rotor and it is a 113 or beetle part number for all years that used them. They could not fit all years of 914 if they work at all. |
Lo-Fi Version | Time is now: 20th May 2024 - 08:13 PM |
