Larmo63
Oct 13 2014, 01:21 PM
What is the diameter of a stock rear 914-4 rotor?
pilothyer
Oct 13 2014, 02:14 PM
QUOTE(Larmo63 @ Oct 13 2014, 02:21 PM)
What is the diameter of a stock rear 914 rotor?
FOR THE 914-6 286 mm 11.2598425 inches
FOR THE 914-4 281.94mm 11.1 inches
Dave_Darling
Oct 13 2014, 04:05 PM
Is that for the -4 or the -6? The -6 rotor is (very) slightly larger.
--DD
pilothyer
Oct 13 2014, 04:07 PM
I gave the dimension for the 6 banger.................. for the 914-4 it is 281.94mm or 11.1in. I edited my first reply to correct info given.
Larmo63
Oct 13 2014, 05:27 PM
Thank you
Cap'n Krusty
Oct 13 2014, 06:46 PM
d=2r
You're welcome!
The Cap'n
stugray
Oct 16 2014, 07:32 PM
I heard from a super-V racer at the track that karman ghia rotors will fit on a 914.
At first I thought "so what".
He said you can order ghia rotors un-drilled and have them drilled for a 5 bolt pattern.
Anyone else heard of that?
I have a full set of 914 rotors laying around, but not a ghia set to compare them to.
bdstone914
Oct 16 2014, 08:34 PM
Ghia ' s only had disc brakes on the front as I recall. So what would be the point over using them over 914 rotors?
And I don't know if any of them were hub centric. I looked up the part number for a Ghia rotor and it is a 113 or beetle part number for all years that used them. They could not fit all years of 914 if they work at all.
