NOS injectors, Should I buy? |
914Next |
Oct 14 2014, 04:28 PM
Senior Member Group: Members Posts: 699 Joined: 28-July 14 From: Ephraim Wisconsin Member No.: 17,695 Region Association: Upper MidWest |
I appreciate all of your patience with my many and varied questions. I think I've read that rebuilt injectors are crap and that we should by new injectors when needed. Mine are not a problem now but I'm wondering if it is a good thing to buy a few of the nos injectors for my 2.0 in the event that I need them down the road. Do they fail often? Or, are there other suppliers of new injectors such that I don't need to be concerned about buying them if/when I ever need them? Thanks
Mblizzard |
Oct 14 2014, 06:38 PM
There are some good reasons to keep a few NOS injectors around. But there are some options for new injectors that are out there. The FJ67 injector works well with the 2.0 and are reasonably priced.
Oct 14 2014, 09:06 PM
As long as I'm spending your money, sure! Get a set, get two! (IMG:style_emoticons/default/biggrin.gif)
--DD |
Oct 14 2014, 09:09 PM
the enemy of our cars is not using them, it's letting them sit. Drive it and everything will last longer and run better.
0396 |
Oct 14 2014, 09:15 PM
Advanced Member Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
There are some good reasons to keep a few NOS injectors around. But there are some options for new injectors that are out there. The FJ67 injector works well with the 2.0 and are reasonably priced. Great info but what is an FJ67 injector ,details please (IMG:style_emoticons/default/piratenanner.gif) |
walterolin |
Oct 14 2014, 09:26 PM
Senior Member Group: Members Posts: 685 Joined: 30-November 11 From: Louisville, Ky Member No.: 13,838 Region Association: South East States |
malcolm2 |
Oct 14 2014, 09:46 PM
Advanced Member Group: Members Posts: 2,745 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
the enemy of our cars is not using them, it's letting them sit. Drive it and everything will last longer and run better. Yes, machines like to run. I sure hope my rebuilt injectors aren't crap.... 1st I heard that they might be? If you do rebuild injectors, don't let them sit around before you start the car. The cleaning fluid will clog them up. |
thelogo |
Oct 14 2014, 10:01 PM
Senior Member Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
Drive the cars and they will run better etc. "" ------------------------------- How about totally stock 1.7 during southern.... California Summers ,103 deg . With no temp or oil gauges . I assume all temp readings would be hot? My car sits for weeks months at a time . Anything I should be doing when the car sits for a prolonged Period of time . Summer time . |
thelogo |
Oct 14 2014, 10:15 PM
And while I'm at it , I personally love and adore my factory f.I car I acknowledge that's it's the best balanced system for all driving conditions / situations
But what would make better performance dual carbs with correct cam but all else stock Or Factory f.I in good or great condition |
Mblizzard |
Oct 15 2014, 04:47 AM
And while I'm at it , I personally love and adore my factory f.I car I acknowledge that's it's the best balanced system for all driving conditions / situations But what would make better performance dual carbs with correct cam but all else stock Or Factory f.I in good or great condition FI will be the better all around performer. Keeping the stock dizzy always seems to inpart an initial hesitation in acceleration and flat spots. The dizzy is designed to work wit FI not carbs. You can certainly build a carb specific engine that will perform better than stock FI. But after you are done you will have very little of your stock engine. |
Mblizzard |
914Next |
Oct 15 2014, 05:28 AM
Thanks guys. Great comments. I hear you on the recommendation to drive it. Plan to do that as much as possible.
dknechtly |
Oct 15 2014, 06:44 AM
Yellow 914 Group: Members Posts: 68 Joined: 11-April 03 From: Wylie, TX Member No.: 560 Region Association: None |
Ditto on driving them; they need it. It's good to have a spare injector or two (and the seals). They are very reliable but at sometime, one is going to leak.
I think you'll find that for a 914 in general, you'll want to start building up some spare parts especially when the day comes that you'll be trouble shooting. Just watch for some good deals on things and grab them as they come. |
Olympic 914 |
Oct 15 2014, 07:08 AM
Group: Members Posts: 1,668 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
the enemy of our cars is not using them, it's letting them sit. Drive it and everything will last longer and run better. Yes, machines like to run. I sure hope my rebuilt injectors aren't crap.... 1st I heard that they might be? If you do rebuild injectors, don't let them sit around before you start the car. The cleaning fluid will clog them up. I might be in for a similar fate. just had my injectors cleaned by Witchhunters and installed them. The rest of the car won't be ready for a while but the engine and trans are done, and sitting in my garage. Any suggestions? maybe squirt some carb cleaner into the injector lines before initial start-up. (IMG:style_emoticons/default/confused24.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 12:30 PM |
