show me yer wing mounts, need some ideas. |
Woody |
Oct 14 2014, 05:07 PM
Sandbox Rabblerouser and head toilet scrubber Group: Members Posts: 3,858 Joined: 28-December 10 From: San Antonio Texas Member No.: 12,530 Region Association: Southwest Region |
J P Stein |
Oct 21 2014, 07:43 AM
Tain't mine no mo.
Best suggestion: bring money. Attached image(s) |
Mugs914 |
Oct 21 2014, 01:06 PM
"Hey, yellow IS faster!" Group: Members Posts: 618 Joined: 22-July 05 From: Temple TEXAS Member No.: 4,452 Region Association: Southwest Region |
Ricer wing mount purchased on the 'bay. Cheap, kinda heavy and strong.
Not the best solution, but it is safe and will do until I can make something better... Cheers, Mike |
Woody |
Oct 22 2014, 10:21 AM
Woody |
Oct 22 2014, 10:22 AM
Woody |
Oct 22 2014, 10:23 AM
J P Stein |
Oct 22 2014, 11:59 AM
That is the same problem Brit has with his rear wing.....it worked too good at speed.....high AX speed, that is.
As you can see in the pic, he then got to work on the front end. |
Heater Guy |
Oct 22 2014, 01:43 PM
Member Group: Members Posts: 74 Joined: 20-October 09 From: Walnut Creek, CA Member No.: 10,960 Region Association: Northern California |
This is the wing used on the World Challenge Mustangs.
Woody |
That is the same problem Brit has with his rear wing.....it worked too good at speed.....high AX speed, that is. As you can see in the pic, he then got to work on the front end. I didn't even have to be going that fast to notice a difference, 40mph and it would understeer. It may be a little too much wing but I'm going to build the splitter before I make that determination. I can also ease off the front bar but then I would be compromising my low speed handling. |
Jetsetsurfshop |
Oct 22 2014, 03:53 PM
Senior Member Group: Members Posts: 814 Joined: 7-April 11 From: Marco Island Florida Member No.: 12,907 Region Association: South East States |
Are you going to make a splitter off your current lower valance? Would love to see some detailed pics of that. I'm currently stuck on selecting a lower valance and I like the one your running. Here's a thread that had some splitter info.
http://www.914world.com/bbs2/index.php?showtopic=237802 Oh, car looks great! (IMG:style_emoticons/default/biggrin.gif) |
Woody |
Oct 22 2014, 08:14 PM
Yes I am. I will do a detailed build on it. (IMG:style_emoticons/default/beerchug.gif)
Heater Guy |
Oct 23 2014, 10:48 AM
Good material for a splitter is a sheet of oak plywood from Home Depot. It is stiff, strong and light weight. A layer of light weight fiberglass cloth seals it and makes it waterproof.
Woody |
Oct 23 2014, 02:59 PM
I am allowed 6" in front of the bumper with XP so this is going to stick out a bit. I would like to make it easily removable so I can get it on and off the trailer.
Heater Guy |
Oct 23 2014, 03:34 PM
Splitters are difficult to attach under the car. Which makes removing them a real pain. This one is 3". You may think about installing a basic 3" splitter and attaching a removable piece to it to provide the 6" total. Or use blocks for your trailer ramps. Be sure to leave space on the sides in case you want to add dive planes later. If you install a wing, you may need to add more front down force than just the splitter. This wing well unload the front tires in high speed turns.
Randal |
Oct 23 2014, 10:58 PM
Good material for a splitter is a sheet of oak plywood from Home Depot. It is stiff, strong and light weight. A layer of light weight fiberglass cloth seals it and makes it waterproof. How much does that front bumper assembly weigh? Was thinking about a u bracket of sorts to slide the splitter into, instead of bolting it. That way you could easily remove the bumper assembly and splitter for loading on to a trailer. |
Randal |
Oct 23 2014, 10:59 PM
Good material for a splitter is a sheet of oak plywood from Home Depot. It is stiff, strong and light weight. A layer of light weight fiberglass cloth seals it and makes it waterproof. How much does that front bumper assembly weigh? Was thinking about a u bracket of sorts to slide the splitter into, instead of bolting it. That way you could easily remove the bumper assembly and splitter for loading on to a trailer. But it might be easier to just build long 2 x 6 ramp extensions to my existing ramps to load. |
Heater Guy |
Oct 24 2014, 07:37 PM
The bumper is light. Not heavy with a lot of resin.
Call Peter at Renspeed and ask him to weigh one (626) 256-8878. He has nice light weight parts and prices are reasonable. But, the freight on big parts is a little pricy. www.rennspeed.com His website is kind of info on top of info. Click on the overlaying parts art the bottom and you will find 914 parts. |
Seabird |
Oct 25 2014, 10:35 AM
Member Group: Members Posts: 165 Joined: 21-November 13 From: United States Member No.: 16,683 Region Association: South East States |
The bumper is light. Not heavy with a lot of resin. Call Peter at Renspeed and ask him to weigh one (626) 256-8878. He has nice light weight parts and prices are reasonable. But, the freight on big parts is a little pricy. www.rennspeed.com His website is kind of info on top of info. Click on the overlaying parts art the bottom and you will find 914 parts. The website must be down the above link just forwards to a tumbler site, which is funny, but alas no 914 parts. (IMG:http://www.914world.com/bbs2/uploads_offsite/41.media.tumblr.com-16683-1414254901.1.jpg) |
Jetsetsurfshop |
Oct 25 2014, 11:03 AM
Found it,
rennspd.com |
J P Stein |
Oct 25 2014, 12:21 PM
The splitter & mounting object should be STOUT. A cone at 50mph (+/- 10) can (and will ) do a surprising amount of damage....then ya runover what's left of your splitter/bumper. A 1/4 sheet of solid carbon fiber is a good place to start.
There are those who say that you should be able to stand on it...... won't go that far, but better to be way too strong than a little too weak. Seen busted ones more than once.....also seen tweaked ones that made the grade....the first time. |
Lo-Fi Version | Time is now: 5th May 2024 - 07:59 PM |
