Welding longs with engine in?, Beginning a resto... |
mbseto |
Oct 15 2014, 09:05 AM
Senior Member Group: Members Posts: 1,253 Joined: 6-August 14 From: Cincy Member No.: 17,743 Region Association: North East States |
Howdy all;
About to start a restoration, hoping to do a rolling resto. After looking over some of the threads on prep for repairing longs, I see two things everyone advises: 1) brace the doors 2) get the car off the wheels, i.e. jackstands under the donuts It looks like the engine is nearly always pulled... Is this a must, or can the longs be repaired with the engine in? If so, is additional support under the engine/trans needed? Thanks for the input, M. |
rjames |
Oct 15 2014, 09:46 AM
I'm made of metal Group: Members Posts: 3,932 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Howdy all; About to start a restoration, hoping to do a rolling resto. After looking over some of the threads on prep for repairing longs, I see two things everyone advises: 1) brace the doors 2) get the car off the wheels, i.e. jackstands under the donuts It looks like the engine is nearly always pulled... Is this a must, or can the longs be repaired with the engine in? If so, is additional support under the engine/trans needed? Thanks for the input, M. Depends on how far back your repairs are going. Unless your repairs extend into the engine bay you won't need need to remove the engine. Apply the bracing as planned so that your gaps don't change. You also don't need to support the engine or tranny. They should already be supported by the engine mount/crossbar and the tranny mounts at the rear. Raising the car off the ground won't change that. Remember to disconnect the battery. Good luck and let's see some pictures of what you'll be fixing! |
Lo-Fi Version | Time is now: 15th May 2024 - 02:01 AM |
