Welding longs with engine in?, Beginning a resto... |
mbseto |
Oct 15 2014, 09:05 AM
Senior Member Group: Members Posts: 1,253 Joined: 6-August 14 From: Cincy Member No.: 17,743 Region Association: North East States |
Howdy all;
About to start a restoration, hoping to do a rolling resto. After looking over some of the threads on prep for repairing longs, I see two things everyone advises: 1) brace the doors 2) get the car off the wheels, i.e. jackstands under the donuts It looks like the engine is nearly always pulled... Is this a must, or can the longs be repaired with the engine in? If so, is additional support under the engine/trans needed? Thanks for the input, M. |
CptTripps |
Oct 15 2014, 12:52 PM
:: Punch and Pie :: Group: Members Posts: 3,584 Joined: 26-December 04 From: Mentor, OH Member No.: 3,342 Region Association: Upper MidWest |
Looks like you may benefit from doing your floor pans too. If it was over damp ground that rotted up through the edges, you may end up going all the way around anyways. You can repair the bottom 3" of the inner longs, but you'll need good metal to weld TO. I did the floors and it really wasn't a hard job at all. Just make sure you have everything level before you go hacking away and welding it back together.
I did my pans, and repaired the longs of my last build with the engine in the car. |
Lo-Fi Version | Time is now: 15th May 2024 - 08:10 AM |
