Newbie here - 1976 914, New owner of a 76' 914 |
Easyb |
Oct 15 2014, 08:31 PM
Member Group: Members Posts: 51 Joined: 13-October 14 From: Houston Member No.: 18,016 Region Association: None |
Hello. I just bought a 1976 914. First Porsche, first pre 80's car.
I'm very excited as have been looking forward to owning one for a while. The car isn't perfect so I'm gearing up to start restomoding it to be more practical and more reliable. I don't know anything about the Porsche, having been a Bimmer guy up to now but I'm eager to learn. Car needs an alternator and probably transmission rebuilt and some other electrical issues. I'm in the Houston area, any one else around this neck of the wood? thanks. EasyB |
Easyb |
Oct 19 2014, 01:47 PM
I plan on going through most of the car and prepare a list of what needs to be repaired.
What i've found so far: - Alternator seems defective. Current one was diagnosed dead (car died several times on the way from seller, drained batteries, performed test from Autozone type of store). - A rubbing noise can be heard when the wheels are turning but a visual inspection to each wheel hasn't revealed anything - nothing seems to touch). The sound is metallic as if the brake shield was touching another part of the wheel. - Electrical needs to be evaluated. Turn signals and rear lights not working. - When driving the car, in 4th/5th gear, engine seems to sometimes "skip a bit" it acts as if it were going to stall but doesn't stall. Still going through the car. Any preferred recommendations on where to order parts from besides eBay, Pelican? Any other areas I should inspect and focus on? Your thoughts???? |
Porky |
Oct 21 2014, 09:44 AM
Newbie Group: Members Posts: 10 Joined: 21-October 14 From: DC Member No.: 18,043 Region Association: MidAtlantic Region |
- A rubbing noise can be heard when the wheels are turning but a visual inspection to each wheel hasn't revealed anything - nothing seems to touch). The sound is metallic as if the brake shield was touching another part of the wheel. noob '76 owner here as well, but i might know the answer to that one. for me it was a seized rear caliper with the outer pad worn completely away, so the metal where the brake pad used to be was just constatly rubbing up against the rusty ol' rotor. |
Lo-Fi Version | Time is now: 20th May 2024 - 06:43 PM |
