BobR |
Newbie ![]() Group: Members Posts: 27 Joined: 8-July 14 From: Silver Springs, FL Member No.: 17,601 Region Association: None ![]() |
This is a link to the first thing you will need for your car, Mom's service covers.
http://www.914world.com/bbs2/index.php?act...t=0#entry578430 |
PanelBilly |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,907 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest ![]() ![]() |
emocleW
Easyb |
Member ![]() ![]() Group: Members Posts: 51 Joined: 13-October 14 From: Houston Member No.: 18,016 Region Association: None ![]() |
I plan on going through most of the car and prepare a list of what needs to be repaired.
What i've found so far: - Alternator seems defective. Current one was diagnosed dead (car died several times on the way from seller, drained batteries, performed test from Autozone type of store). - A rubbing noise can be heard when the wheels are turning but a visual inspection to each wheel hasn't revealed anything - nothing seems to touch). The sound is metallic as if the brake shield was touching another part of the wheel. - Electrical needs to be evaluated. Turn signals and rear lights not working. - When driving the car, in 4th/5th gear, engine seems to sometimes "skip a bit" it acts as if it were going to stall but doesn't stall. Still going through the car. Any preferred recommendations on where to order parts from besides eBay, Pelican? Any other areas I should inspect and focus on? Your thoughts???? |
barefoot |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,415 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States ![]() ![]() |
I plan on going through most of the car and prepare a list of what needs to be repaired. What i've found so far: - Alternator seems defective. Current one was diagnosed dead (car died several times on the way from seller, drained batteries, performed test from Autozone type of store). - A rubbing noise can be heard when the wheels are turning but a visual inspection to each wheel hasn't revealed anything - nothing seems to touch). The sound is metallic as if the brake shield was touching another part of the wheel. - Electrical needs to be evaluated. Turn signals and rear lights not working. - When driving the car, in 4th/5th gear, engine seems to sometimes "skip a bit" it acts as if it were going to stall but doesn't stall. Still going through the car. Any preferred recommendations on where to order parts from besides eBay, Pelican? Any other areas I should inspect and focus on? Your thoughts???? Look at Auto Atlanta site, they have very helpful exploded parts diagrams for most everything. Click on one of the images and a P/L appears keyed to the item numbers in the diagrams. They tend to be pricey however. For any rubber weatherstripping, 914 Rubber is where to go. Barefoot |
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
Just a thought on the alternator. Do you have alt light with the ignition on. The alternator circuit depends on that circuit to supply power to the field on the alternator. Before you pull it. Make sure you have the light, or that there is not a LED installed.
Always nice if it's an easy fix. You will find grounding is an issue on this car. Many problems can be attributed to grounding. So before you dig too far in check the easy stuff. Sometimes you get lucky. |
rick 918-S |
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,041 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region ![]() ![]() ![]() |
Full on brake job if the car has been sitting. (IMG:style_emoticons/default/welcome.png)
Easyb |
Just a thought on the alternator. Do you have alt light with the ignition on. The alternator circuit depends on that circuit to supply power to the field on the alternator. Before you pull it. Make sure you have the light, or that there is not a LED installed. Always nice if it's an easy fix. You will find grounding is an issue on this car. Many problems can be attributed to grounding. So before you dig too far in check the easy stuff. Sometimes you get lucky. Can you clarify? If the Alternator light is ON, is it bad or good? WHen I drove the car back, it was night time and all the lights on the gauge were very dim, barely readable unless I use an external light source. When I used the headlights, the battery was drained in a matter of minutes and the car will die at a STOP or Traffic light. I had to jump it 6 times to make it home. For grounding, should I just go around and check to see if every part that has a ground wire is grounded? I've checked it on the battery side already. |
Easyb |
Brakes is definitely on my list. The pedal is a bit loose. Is upgrading brakes on this car mandatory? If yes, what should I consider. The purpose will be DD and may be a couple of AutoX here and there but mostly DD. |
Porky |
Newbie ![]() Group: Members Posts: 10 Joined: 21-October 14 From: DC Member No.: 18,043 Region Association: MidAtlantic Region ![]() |
- A rubbing noise can be heard when the wheels are turning but a visual inspection to each wheel hasn't revealed anything - nothing seems to touch). The sound is metallic as if the brake shield was touching another part of the wheel. noob '76 owner here as well, but i might know the answer to that one. for me it was a seized rear caliper with the outer pad worn completely away, so the metal where the brake pad used to be was just constatly rubbing up against the rusty ol' rotor. |
Beeliner |
Member ![]() ![]() Group: Members Posts: 398 Joined: 2-August 14 From: Fairfield, CT Member No.: 17,725 Region Association: North East States ![]() ![]() |
I was resigned to buying an alternator when my mechanic cleaned up the ground connection.
Bingo, problem solved.... |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,249 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
I think mark wants to know if the light is on when the key is turned. Prior to the cranking position.
malcolm2 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,749 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States ![]() ![]() |
I struggled a bit with the ALT. I ended up getting mine rebuilt. The ALT for the type 4 engine has various special nooks and crannies that the NAPA version does not have. I am sure someone sells the right model, but rebuild for me was pretty cheap and is working great.
My guy was local to me, so I bet you can find someone in Houston. I don't think there is anything special to rebuild them, just have to ask around. |
Easyb |
Thanks a lot for all the replies.
The alternator light doesn't come on when the key is turned on or at any other times. Other lights come on as expected. This weekend, I'll attempt to clean the ground wire, check other connections, and then if needed, remove the alternator. |
mdelwiche |
Vegas_914 ![]() ![]() Group: Members Posts: 59 Joined: 17-March 12 From: Tucson, AZ Member No.: 14,266 Region Association: Southwest Region ![]() |
Welcome from another '76 owner. Just wrapping a two year rebuild of my car. The people here are great and helped me along the way with advice and sourcing parts!!! |
Bleyseng |
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,036 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest ![]() |
Brakes is definitely on my list. The pedal is a bit loose. Is upgrading brakes on this car mandatory? If yes, what should I consider. The purpose will be DD and may be a couple of AutoX here and there but mostly DD. Have them rebuilt by Eric Shea at PMB and install Porterfield pads and you'll have plenty of braking power for a stock car. |
Easyb |
Quick update: alternator problem solved, had to rebuild the alternator and replace the alternator bulb in the dash. Now working fine.
Now working on brakes, starting with the rear calipers. Pads are worn out and a caliber piston is stuck and won't press back. This grounded the rotor in the rear. Trying to decide between rebuilding it myself using the DIY caliper rebuild kits or sending it to a place like PMB. Ideas? |
mdelwiche |
Quick update: alternator problem solved, had to rebuild the alternator and replace the alternator bulb in the dash. Now working fine. Now working on brakes, starting with the rear calipers. Pads are worn out and a caliber piston is stuck and won't press back. This grounded the rotor in the rear. Trying to decide between rebuilding it myself using the DIY caliper rebuild kits or sending it to a place like PMB. Ideas? I rebuilt both my front and rear with kits from PMB. I definitely appreciated the experience, but I ran into a few issues with the pistions and inner mechanisms that when it was all said in done, I really didn't save any money from doing it myself. If I were to do it again, I'd just send them to PMB. |
Easyb |
Quick update: alternator problem solved, had to rebuild the alternator and replace the alternator bulb in the dash. Now working fine. Now working on brakes, starting with the rear calipers. Pads are worn out and a caliber piston is stuck and won't press back. This grounded the rotor in the rear. Trying to decide between rebuilding it myself using the DIY caliper rebuild kits or sending it to a place like PMB. Ideas? I rebuilt both my front and rear with kits from PMB. I definitely appreciated the experience, but I ran into a few issues with the pistions and inner mechanisms that when it was all said in done, I really didn't save any money from doing it myself. If I were to do it again, I'd just send them to PMB. Yes, I considered sending the calipers to PMB but I'm trying to DIY. What were the complications you experienced with the pistons? Any lessons learned to be shared? |
hndyhrr |
Senior Member ![]() ![]() ![]() Group: Members Posts: 628 Joined: 1-September 13 From: central point,oregon Member No.: 16,332 Region Association: Pacific Northwest ![]() ![]() |
Quick update: alternator problem solved, had to rebuild the alternator and replace the alternator bulb in the dash. Now working fine. Now working on brakes, starting with the rear calipers. Pads are worn out and a caliber piston is stuck and won't press back. This grounded the rotor in the rear. Trying to decide between rebuilding it myself using the DIY caliper rebuild kits or sending it to a place like PMB. Ideas? I rebuilt both my front and rear with kits from PMB. I definitely appreciated the experience, but I ran into a few issues with the pistions and inner mechanisms that when it was all said in done, I really didn't save any money from doing it myself. If I were to do it again, I'd just send them to PMB. Yes, I considered sending the calipers to PMB but I'm trying to DIY. What were the complications you experienced with the pistons? Any lessons learned to be shared? I saved some money doing the rebuild(backs) myself. pmb video is the bomb, my problem was the gear to sent vent clearance was trashed, ordered new gear and all is well. I had to replace my disc on back brakes so this weekend bleeding the brakes and if no rain burning in pads to disc. |
Lo-Fi Version | Time is now: 31st July 2025 - 11:39 AM |
