Converting to a 914-6, I am not a mechanic... Am I crazy....? |
Beeliner |
Oct 21 2014, 05:54 PM
Member Group: Members Posts: 398 Joined: 2-August 14 From: Fairfield, CT Member No.: 17,725 Region Association: North East States |
I purchased a 1975 914 that is very original, except for the change of color.
This is my fifth one. I bought three new in the seventies, and two recently. The problem is that I will be mostly supplying the money, and not the expertise... My mechanic is factory trained and was drooling over the opportunity. He just finished a Boxster rebuild over the weekend. Here is a picture of the car. It recently had a rustectomy and new paint. The engine and car is now stock all the way, original FI is still there. It is a DD. I know the car will have to be strengthened, sway bars added, and all of that... But is this an insane project when one is not a mechanic? I don't want flared fenders, so no major exterior cosmetics are to be done... Is $9k for motor and parts reasonable? My mechanic wants to rebuild the engine, so one needing work is what we are looking for. Attached thumbnail(s) Attached image(s) |
Steve |
Oct 21 2014, 07:15 PM
914 Guru Group: Members Posts: 5,585 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Do your homework.... It's a slippery slope....
Compare the motor with the car it came out of. You should at a minimum, match the brakes to the motor as well as suspension and tires. My first six conversion in a 914 was a 2.7. I also did a 5 lug conversion and went with bigger brakes at the same time. I still had throttle induced over-steer from the motor so i flared the rear fenders for bigger tires. I was very happy with the setup, but the 2.7 was more expensive to overhaul than a 3.2 from a wrecking yard, so i upgraded to a 3.2. For the street I was not happy with the 914/901 gearing with the 3.2, so i replaced the 914 trans with a 915 trans that matched my motor. I will probably upgrade to a 3.6 next, but at least all the other components should be fine. |
Lo-Fi Version | Time is now: 16th May 2024 - 12:26 AM |
