901 tailshift, tail shift adjuster |
Mike1981 |
Oct 22 2014, 06:44 AM
Member Group: Members Posts: 212 Joined: 21-July 14 From: Detroit MI Member No.: 17,663 Region Association: Southern California |
Hello
I have been following this thread closely and saving my pennies to buy one of these adjusters My 914 has a tailshift 901 tranny and I just read this will not work on a tailshift Is there a similar tool one can buy to help with the adjustment of the shifter? The P.O. replaced all the bushings but I'm dealing with a renegade with a custom linkage Tranny shifts fine but finding the gears is still a problem. Im told trying to adjust without experience may lead to making matters worse Any help on this? Thanks Mike |
dknechtly |
Oct 23 2014, 07:17 AM
Yellow 914 Group: Members Posts: 68 Joined: 11-April 03 From: Wylie, TX Member No.: 560 Region Association: None |
First step is to replace all the plastic bushings, balls and cups. This alone will gve a vast improvement. If there is a lot of side-to-side slop in the very back (where the linkage couples to the tranny), I've had good luck putting a homemade shim between the metal ball of the linkage and the shift lever. I made mine of house heat/air ducting type metal. Make it big enough with some tabs so you can kind of wrap it around to stay put.
Lo-Fi Version | Time is now: 15th May 2024 - 01:21 PM |
