Engine Condition - 2.0L |
mmascari |
Oct 22 2014, 10:45 AM
Member Group: Members Posts: 321 Joined: 1-September 14 From: Concord, CA Member No.: 17,850 Region Association: None |
I recently purchased a 1973 2.0L that I am in the process of restoring. According to the previous owner the engine hasn't run in 5 years. I drained the oil which looked OK. The other day I dropped the engine out and was going to take a look at it. My question relates to if the motor is ceased. I am able to turn the fan clockwise and counter-clockwise but only about 180 degrees. Is that normal? I am not a mechanic so I have no idea. What other things can I do or verify that the engine is good? For example, pull the heads? I will take the valve covers off today and post some pics. Thanks in advance for the advice.
bdstone914 |
Oct 22 2014, 11:08 AM
bdstone914 Group: Members Posts: 4,522 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I have had several engines like that which had rusted rings in one cylinder from sitting for a long time with a valve open. Might as well start to remove the heads to see what you have.
Lo-Fi Version | Time is now: 19th May 2024 - 11:09 PM |
