my 912e just passed ca smog |
rosenfe |
Oct 23 2014, 04:51 PM
Senior Member Group: Members Posts: 549 Joined: 14-October 13 From: northern california Member No.: 16,512 Region Association: None |
hooray,im relieved.im very happy i got the car.
Krieger |
Oct 23 2014, 05:18 PM
Advanced Member Group: Members Posts: 4,704 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
Nice work!
Cuda911 |
Oct 23 2014, 11:44 PM
Senior Member Group: Members Posts: 1,489 Joined: 20-May 14 From: Oceanside (N. San Diego County), CA Member No.: 17,376 Region Association: Southern California |
Congrats!
I love 912s, and plan to get one. I despise CARB and its frickin' moronic dictates. |
Mikey914 |
Oct 24 2014, 01:36 AM
The rubber man Group: Members Posts: 12,640 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
His is an E
It's injected. Congrats, you don't need no stinking reactors! How about some pics Attached thumbnail(s) |
EdwardBlume |
Oct 24 2014, 06:27 AM
Lucky you. When I still had to smog the '74, I took it to a shop who flat out told me they couldn't smog it because they didn't know what they were looking at...
rosenfe |
Oct 24 2014, 12:09 PM
i am fortunate to have several good porsche shops with experience getting 912e through smog.
i now understand how special 911s are.the 912e is a 76 911 with a 914 motor.there is definitely something special as to how it handles and feels.i still love my 914 as well. my gas pedal gets sticky on the 912e and i wonder if the the throttle body valve can be a source of resistance if dirty.?anybody have experience with this?.ive added some wd40 to throttle cable and it did help. |
dangrouche |
Oct 24 2014, 06:20 PM
dangrouche Group: Members Posts: 550 Joined: 1-May 04 From: San Francisco Bay Area Member No.: 2,012 Region Association: None |
I have a 74 2.0 914 with factory injection. one of the things to look at is the pivot shaft of the throttle body. disconnect the cable at the throttle body and see if throttle plate pivots smoothly. while the cable is disconnected from the throttle body see if the cable moves to and fro by having a helper press on the accelerator cable. if you are alone, you could also disconnect the cable at the pedal end and while standing over the motor, see if the cable moves smoothly to and fro. Hopefully you will only need a cable.
Cap'n Krusty |
Oct 24 2014, 06:23 PM
How'd you get it passed without the air pump? The T/Rs I can understand, cause you can't readily see 'em.
The Cap'n |
bdstone914 |
Oct 24 2014, 06:41 PM
bdstone914 Group: Members Posts: 4,514 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
How'd you get it passed without the air pump? The T/Rs I can understand, cause you can't readily see 'em. The Cap'n I sold him an air pump and pulley (IMG:style_emoticons/default/beerchug.gif) Bruce |
rosenfe |
Oct 25 2014, 09:48 AM
yes,bruce came to the rescue with the right parts.
Cap'n Krusty |
Oct 25 2014, 10:38 AM
Ahhhh ... In my starving-just-before-dinner fog, I thought those pictures were of the car in question. I see they're not. Pardon the flaw in my perfection ...
The Cap'n |
rosenfe |
Oct 25 2014, 11:05 AM
i found a loose vacuum. line,thats why idle was so erratic.cleaned out the throttle body and butterfly valve .there was a ridge binding up butterfly,now it runs perfectly.getting more familiar with engine.great car
KELTY360 |
Oct 25 2014, 01:48 PM
914 Neferati Group: Members Posts: 5,031 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest |
RenoRoger |
Oct 25 2014, 05:42 PM
Member Group: Members Posts: 95 Joined: 11-November 10 From: Reno, NV Member No.: 12,370 Region Association: Northern California |
[quote name='Mikey914' date='Oct 24 2014, 12:36 AM' post='2101863']
His is an E It's injected. Hi Mickey914; I also own a 912E, bone stock. What's that little round can next to your blue coil. Except for that my engine compartment looks exactly like yours. RenoRoger |
Mikey914 |
Oct 25 2014, 05:46 PM
Some type of a diaphragm on the vacuum circuit. Didn't know it wasn't stock. Maybe an PO modification to pass without the pump, as it does.
Krieger |
Oct 25 2014, 06:15 PM
It looks like an oil temp/pressure sender. The hose loops up and then down to the stock sender location.
Cap'n Krusty |
Oct 25 2014, 06:28 PM
[quote name='RenoRoger' date='Oct 25 2014, 04:42 PM' post='2102567']
[quote name='Mikey914' date='Oct 24 2014, 12:36 AM' post='2101863'] His is an E It's injected. Hi Mickey914; I also own a 912E, bone stock. What's that little round can next to your blue coil. Except for that my engine compartment looks exactly like yours. RenoRoger [/quote] The "little round can" next to the ignition coil is an oil pressure sending unit with terminals for both the light and a gauge. Note the high pressure hose that goes to the original port for the OP switch. The Cap'n |
Lo-Fi Version | Time is now: 29th April 2024 - 11:38 AM |
