6 Pages V « < 3 4 5 6 >
> LED headlights, LED head lights
Chris914n6
post Nov 24 2014, 03:06 PM
Post #81
Jackstands are my life.
Heat is not a problem. The SEMA displays were on half a day when I got there. The rear housing is one big aluminum heatsink.
The replacement bulbs wouldn't fit so it's mute.
dale73914
post Nov 24 2014, 05:16 PM
Post #82
Region Association: Australia and New Zealand
After driving mine all through winter here iin Australia, i have been folloowing this with much interest.
Thinking i now know what Santa is bringing.....
post Nov 24 2014, 05:43 PM
Post #83
914-6 GT in waiting
It's a great upgrade and would take 5 minutes to reverse if you needed to. I'm really glad you guys let me In on this product.
Chris Pincetich
post Jan 12 2015, 08:12 PM
Post #84
B-)
After driving with these for about a month I can say this is an awesome upgrade! (IMG:style_emoticons/default/beerchug.gif)
The light is super bright compared to my not very old 55W H-4s, which were way brighter than OEM set-up that was in there 10 years ago. They are worth adjusting, as the light spread improved when I aimed them up a bit. I added a link to the reviews on Amazon - a lot is written. I was happy to read that I am not the only one to notice the bright "X" formed in the middle of the road by the somewhat angular hot-spots in the pattern of light (IMG:style_emoticons/default/biggrin.gif)
Overall, bright, WIDE, white light 2-4x brighter than standard options and the install is plug-n-play. I was constantly "over driving" my old lights during PM forays on the local twisty forest roads, but now can see way ahead and much farther around corners as I cruise at 55mph (IMG:style_emoticons/default/aktion035.gif)
I can't comment on the high beams. Mine don't work (IMG:style_emoticons/default/dry.gif)
Need to fix that, but less important now w these new headlights.
http://www.amazon.com/GE-NIGHTHAWK-Round-R...yRankDescending
FourBlades
post Jan 12 2015, 09:32 PM
Post #85
From Wreck to Rockin
Still loving mine.
I look forward to driving at night now...
John
post Jan 12 2015, 09:39 PM
Post #86
914-6 GT in waiting
QUOTE(Chris Pincetich @ Jan 12 2015, 09:12 PM) *
You need to fix your high beams. They are too bright to use around traffic but light up like the sun on an empty road. If both your highs are out, it might be your car and not the lights.
Chris Pincetich
post Jan 12 2015, 10:18 PM
Post #87
B-)
Yup, it's not the new headlights. I have the Jwest flasher, Jwest fuse assembly, and a "newer" wiper stalk assembly, so all of that wiring has been messed with and I obviously didn't put something together correctly. I've replaced the relay, added that "jumper" to it, and still I can't get the little blue light or "click" to indicate the high beams should be working.... (IMG:style_emoticons/default/sad.gif)
mobymutt
post Jan 13 2015, 07:17 PM
Post #88
Those headlights are amazing! Can we get them at a discount in bulk?? Group buy!
db9146
post Feb 25 2015, 08:36 PM
Post #89
Any other source or coupon known for these?
infraredcalvin
post Feb 26 2015, 08:42 AM
Post #90
Distracted Member
QUOTE(db9146 @ Feb 25 2015, 06:36 PM) *
rmdinmd
post May 25 2015, 06:40 AM
Post #91
just ordered mine. Amazon has the $100 off coupon which brings the price with shipping to just under $200 each. I placed two seperate orders for 1 each to use the coupon for each order. It says you can't do that but it seems to let you. (IMG:style_emoticons/default/biggrin.gif)
Cairo94507
post May 25 2015, 06:48 AM
Post #92
Michael
Yup- that is how I bought mine too. (IMG:style_emoticons/default/agree.gif)
post May 25 2015, 07:45 AM
Post #93
914-6 GT in waiting
QUOTE(Cairo94507 @ May 25 2015, 08:48 AM) *
me 2. I can't imagine that you won't be very happy with the lights. I sometimes use mine as daytime running lights since I know the lifespan is multiples of normal lights.
SKL1
post May 26 2015, 10:53 AM
Post #94
I'm in the process of doing the relay wiring with the jwest kit for my new H4's and now I see this thread!!
Can I assume you don't need the relay set up with these lights as they don't draw a big current?? That would sure simplify things...
Cairo94507
post May 26 2015, 11:21 AM
Post #95
Michael
That is correct. Just remove the old and plug in the new.
SKL1
post May 26 2015, 11:45 AM
Post #96
just ordered with my wife's prime acct. did 2 orders and both took the coupon. It just asked me if I wanted a duplicate order as I did them both back to back. anxious to try them out! probably will end up with them on both cars!!
dangerranger01
post May 27 2015, 09:29 PM
Post #97
These are awesome.
My lights should arrive tomorrow....is there any difference between left and right hand sides? Couldn't find much info.
Regardless, this upgrade is going to be amazing!
dangerranger01
post Jun 10 2015, 08:58 PM
Post #98
Excuse my newbness, but is there a way to leave the headlights up and not have any lights stay on? I can only get them to stay up and have the running lights stay on. Tried a bunch of different combos of key and switch positions but couldn't figure it out....or is my wiring jacked up?
zambezi
post Jun 10 2015, 09:35 PM
Post #99
yes, pull the round relay by the light motor, then turn off the lights
dangerranger01
post Jun 10 2015, 09:45 PM
Post #100
^^thanks. Does that relay control the motor or the bulb, or both?
never mind...found it in my wiring diagram. it is only for the motor.
- Lo-Fi Version Time is now: 21st September 2026 - 11:35 AM
