GB - Improved tail cone speedo drive with additional seal, Thanks to McMark for this one, stop a leak! $42.99 - $65 after GB |
Mikey914 |
Oct 25 2014, 03:15 PM
The rubber man Group: Members Posts: 12,660 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
This is a service that McMark had been doing for some time. It adds an additional sealing surface to the speedo drive bushing by cutting a channel in the OEM part. It required you to send in yours and he had to have a few to make it worth while, so it took a little time to get these together.
After speaking with him regarding this, we came to an arrangement, that would allow for new ones to be on the shelf for those that need them at the shop, or just want a local pick up. So you can buy from him or I will also stock on my site. Either way, it's better than the exchange program. And by the way the OEM non modified part is over $150. For those of you that are not quite sure what the significance of this is, it adds the extra seal to eliminate the nagging drip off the speedo angle drive. It comes with the 2 o-ring seals and the internal drive seal. These will be up on the site shortly to allow to combine with any other GB's Bump if you want to be notified when up. Also one of those while you're down there with the clutch cable jobs. Attached image(s) |
Daiberl |
Nov 1 2014, 11:35 PM
Senior Member Group: Members Posts: 574 Joined: 22-June 09 From: Seattle, WA Member No.: 10,497 Region Association: Pacific Northwest |
Add me for 2 please.
Lo-Fi Version | Time is now: 13th May 2024 - 08:56 AM |
