Mikey914
Oct 25 2014, 03:15 PM
This is a service that McMark had been doing for some time. It adds an additional sealing surface to the speedo drive bushing by cutting a channel in the OEM part. It required you to send in yours and he had to have a few to make it worth while, so it took a little time to get these together.
After speaking with him regarding this, we came to an arrangement, that would allow for new ones to be on the shelf for those that need them at the shop, or just want a local pick up. So you can buy from him or I will also stock on my site. Either way, it's better than the exchange program.
And by the way the OEM non modified part is over $150.
For those of you that are not quite sure what the significance of this is, it adds the extra seal to eliminate the nagging drip off the speedo angle drive.
It comes with the 2 o-ring seals and the internal drive seal.
These will be up on the site shortly to allow to combine with any other GB's Bump if you want to be notified when up.
Also one of those while you're down there with the clutch cable jobs.
Mikey914
Oct 25 2014, 03:19 PM
The process is pretty straight forward. However you will need to change your trans fluid, or at least strain if you have done so recently. As this is in a low point submerged in the trans fluid.
Once the old one is removed allow 30 min for it to drain.
Take the old geared shaft from the removed unit, as well as the washer and set aside.
Put the shaft into the new bushing, and set it as the base.
Mikey914
Oct 25 2014, 03:20 PM
Take the seal shown (the bottom side is shown) and set onto the shaft.
Mikey914
Oct 25 2014, 03:22 PM
Lubricate, I used WD40 as it's not real messy. Then using a socket (I used 13mm, but a 12 is a little closer) Gently tap the seal into place. It is a tight fit, but once seated is very difficult to remove.
Mikey914
Oct 25 2014, 03:24 PM
Don't forget to replace reinstall the aluminum washer. These are $9 from Porsche so don't loose it.
Mikey914
Oct 25 2014, 03:26 PM
Once you have the gear and seal in you can install so that the hole in the unit lines up with the bolt hole in the tail cone assembly.
I did use WD40 to install as it is a tight fit.
Mikey914
Oct 25 2014, 03:28 PM
PLEASE NOTE -
You do not have to take off the tail cone assembly to do this. I happened to have an extra part so it was easy to show this.
However if you do wish to I have the tail cone gaskets only for $5 on the site.
I have one last GB to list, and then I will be adding to the site, so bump if you are a +1, I'll notify everyone on the thread.
Thanks all!
Cap'n Krusty
I can tell you that this WORKS! I've bought several of them from McMark and used them to fix transaxles that have suffered from years, if not decades, of speedo drive leaks. This should be part of every 914 trans overhaul, or even "freshening up".
The Cap'n
pilothyer
Oct 25 2014, 03:37 PM
Remind me for 2 of these.
walterolin
Oct 25 2014, 03:49 PM
One.
McMark
Oct 25 2014, 06:32 PM
Thanks for taking this over Mark. No more cores to deal with now!
GermermanCarGuy
Oct 25 2014, 07:07 PM
One please.
restore2seater
Oct 25 2014, 09:54 PM
Put me down for one.
carr914
Oct 26 2014, 02:18 AM
I want 3 Please!
Java2570
Oct 26 2014, 06:55 AM
Put me down for one, please!
Dtjaden
Oct 26 2014, 09:26 AM
I'll go for one!
kid914
Oct 26 2014, 09:56 AM
So this is for trannies? 901- 915?
Mikey914
Oct 26 2014, 11:09 AM
911- 1965-1973
914 all
It's equivalent to part # 901.318.243.12
I believe it's a 901 only
wes
+1 for me
7275914911
Oct 26 2014, 12:13 PM
I need 1 of these plus in on Badge buy also....
matt_o_70
Oct 26 2014, 01:44 PM
+1 I need to fix.
Matt
Mikey914
Oct 26 2014, 06:09 PM
All PM's sent
EdwardBlume
Oct 26 2014, 06:13 PM
I'll take one of these too...
Zimms
Oct 27 2014, 06:56 AM
In for one.
Mikey914
Oct 28 2014, 09:29 AM
Bump for Rhodyguy
914_3.0
Oct 28 2014, 09:32 AM
Love mine!! No more drips on the floor!! Thanks again McMark
rhodyguy
Oct 28 2014, 09:41 AM
Thanks mark.
K
larryM
Oct 30 2014, 10:28 PM
+1 for me too
MartyYeoman
Oct 30 2014, 10:30 PM
Count me in for one too.
02loftsmoor
Oct 31 2014, 07:01 AM
QUOTE(Mikey914 @ Oct 25 2014, 04:15 PM)
I need in one please
914werke
Oct 31 2014, 08:24 AM
One please
SLITS
Oct 31 2014, 08:55 AM
One here please
Java2570
Nov 1 2014, 09:32 AM
Just got mine in the mail today! Thanks Mark & 914 Rubber for being such a great vendor for our 914's!!
carr914
Nov 1 2014, 09:45 AM
QUOTE(Mikey914 @ Oct 26 2014, 08:09 PM)
All PM's sent
I never heard from you!
FL000
Nov 1 2014, 11:22 AM
+1 for me
Tedman5
Nov 1 2014, 01:03 PM
PM sent. +1 plus something else. Lol
abes914
Nov 1 2014, 01:40 PM
+1 please. and thanks for doing this.
MartyYeoman
Nov 1 2014, 08:00 PM
Am I waiting for comformation?
Mikey914
Nov 1 2014, 10:10 PM
PM's sent to all so far.
I did a generic form letter to all with a link. As there are several other item you may wish to combine to save some money on shipping.
Thanks
Mark
Daiberl
Nov 1 2014, 11:35 PM
Add me for 2 please.
lonewolfe
Nov 1 2014, 11:55 PM
I'd like one please!
spaceshuttle
Nov 2 2014, 08:18 AM
I would like a couple.
Thanks
Mikey914
Nov 2 2014, 01:52 PM
PM's sent to all THX
914bub
Nov 2 2014, 02:29 PM
If it's not too late,I'd like one also.
JamesM
Nov 2 2014, 08:22 PM
i am down for a couple
DMCF1Fast
Nov 2 2014, 09:31 PM
I'd like one also if still available. PM'd you.
Thanks,
David
hcdmueller
Nov 2 2014, 11:08 PM
I will take one too!
