Aussie 914 Restoration |
barrym |
Oct 26 2014, 04:05 PM
Member Group: Members Posts: 88 Joined: 12-October 14 From: Australia Member No.: 18,008 Region Association: None |
First time post of lurking here for a while.
I bought a '75 914 a couple of weeks ago that had already been partly pulled apart to restore- its mostly complete but needs to be further pulled down to repair the rust & make mods to it for my intended purpose. it already came as right hand drive and has an amazingly good condition dash board. I have no history with the car so cant tell who or when the conversion was done. I don't even know if it was a US or European import, or if it was an aussie delivered car ... how can I tell ??? it has a scallop out of the right hand side chassis rail for the handbrake, but not the left hand side ... it used to be viper green and has had a poor respray in red - it's going back to viper green (IMG:style_emoticons/default/smile.gif) I have some garage space with a couple of chaps who has worked on 14's before which is a HUGE help to me, very lucky as i'm new to Porsche having owned lotus's for years (and still do). the plan is to restore it for partial road use but mostly track & tarmac rally. in the short term I plan to drop a 3.0 Subaru engine in while I build up funds & parts for a 2.7 Porsche engine. Its been in dry storage for at least 11 years than I know of, and possibly more before that. anyway, am documenting my rebuild thread here. I've made a start on removing the hacked up loom & vacuuming all the loose rust out. Its better than expected (as I bought the car only from pictures) it needs; new hell holes back of floorpan & bottom of firewall boot and that's about it - the rest of it looks (at this stage) like only surface rust - the suspension consoles are solid as is the majority of the front boot - again, only surface rust there ... the windscreen will come out next to get access to pull out the dash so I can continue to remove the loom. i'll be making up a new loom for it. question though - how do I remove the left hand seat ? the lever at the side does nothing - possibly broken ? and there is no handle at the front to slide the seat forwards to get at the rear bolts ... stumped on this one ... Attached image(s) |
barrym |
Nov 25 2014, 05:56 PM
been a few weeks since updates - have been away with work, but have also made some progress.
fabricated new harness mounting points for install in the centre section - upon advice from another 914 member the standard points are a little too far forwards with the harness buckle ending up on the seat rather than between seat & mount point. anyway, this allows me to use the standard mount point for the standard seatbelt as well, if I choose to use it. mostly finished making the new floor & welded it in place. with the seat in place I now fit comfortably in the car, with enough room for roll cage & helmet/hans and can still see over the steering wheel. the new floor is approx. 40mm lower at the back and 15mm lower at the front. I've yet to complete the welding in of replacement cross floor beams. a bunch of stuff has arrived from the US and will keep me busy for some time. next on the list to do is remove shelf in engine bay & fix up the rear inner guards - then replace the boot floor. Attached image(s) |
Lo-Fi Version | Time is now: 19th May 2024 - 01:28 AM |
